Trusses at Non Load Bearing "Partition" Walls
I have always had an issue with my company's lack of detailing the interaction (or what I think should be a lack thereof) of floor and roof trusses passing over non load bearing (NLB) walls. We dictate which walls in a structure are to be LB and, without making any special recommendations, seem to assume that if the contractor erects the truss in a way that it is in contact with a non structural element like a partition wall that there will be negligible effect. I tend to disagree. If there is a 30 foot truss span, the space is split down the middle at by a partition wall, and the truss bears on all three walls, the middle reaction at the partition wall is greater (about 25%) than the two reactions at the walls that are supposed to be LB! Even in the case that the truss was erected such that it was slightly above and not in contact with the NLB wall, if it deflected enough after the building was occupied and loaded, then the reaction will immediately occur upon their contact in my opinion.
In attempt to remedy this, I drew up some details that could be used to ensure the framing elements are not in contact with partition walls but are still connected to the NLB walls via slip track connectors and someone above me "poo-poo'd" the idea insinuating that not designating those walls as LB is good enough and that somehow the lack of vertical members in the truss directly above NLB walls basically causes no reaction to occur. When I pushed on that notion (because I completely don't agree) it changed slightly to the notion that if they were in contact the worse that would happen was that the bottom chord of the truss would deflect a little bit. I remember walking through truss design in Structural Analysis but I don't remember anything like that notion. I wouldn't treat a truss exactly like a beam for precise design, but for something conceptual like this I think its safe to assume that the reaction in a three span condition occurs similarly to a more typical beam.
Another issue I have with it is the "internal" forces within the truss. The truss web members have a very specific "layout" of tension and compression members. I am fairly positive that introducing a reaction that wasn't intended/included in design can screw that entire system up.
Am I getting this wrong, somehow? I feel this is a bigger deal than its being treated.
RE: Trusses at Non Load Bearing "Partition" Walls
The practice: problems arise infrequenly enough that detailing for the movement may be viewed as a costly solution to an imaginary problem. That's how it's been in the markets that I've practiced in so far.
Note: The fact that the contractor proposed an alternate solution that he had used many times before, shows that it is fairly common practice in my area to have separation between trusses and non load bearing walls.
This is not an imaginary problem.
Mike McCann, PE, SE (WA)
I'm curious what the sheetrockers can do. I've always wondered what happens in these situations where the truss can move on a clip, but the drywall can't.
John
Link
The main ingredient is, of course, a sympathetic drywall team.
