Direct tooling OOA mold material
thread327-391908: tooling material
For the production of a very small serie (max 2 products), I will be using OOA, vacuum bag only CF prepreg. I will be using a cure of 70°C and a post cure of 90°C. The tooling material I will be using has a CTE of 25 µm/m°C. The minimal draft angle of my object is 2°.
As I don't have a lot of experience in this matter, I would like to know if the difference in thermal expansion between the carbon fiber ant the tooling board would cause problems? Or is it nessecary to use a better (more expensive) tooling board?
RE: Direct tooling OOA mold material
