Change how NX saves new drawing file
Using NX9, when I create a new drawing it defaults to the prefix _dwg, is there a setting by which I can change what this defaults as?
RE: Change how NX saves new drawing file
www.nxjournaling.com
I.e NX uses the same type of file for all purposes, modeling , drafting, assemblies, sheet metal etc.
The exception is simulation files which get other file name extensions than .prt.
( Even if i suspect that the file itself still is identical to a .prt)
Tomas
Look again to the place Cowski described, the entry you look for is the "Drafting Parts" ( = "dwg")
Above this section is the setting to define the "file name separator" = "_"
Tomas
Not that I had looked and couldn't as this is what I had previously done.
