How do you dispose batteries
Hello all,
I would like to do a project on safe disposal of batteries. But I need some ideas and suggestions from you all to start my project. It's just one of my thought, but really wish to get it implemented. Any ideas are greatly welcomed.
RE: How do you dispose batteries
Now I have no idea what Excide does with old batteries.
The rest of the year I live in a county of over a million people. They gave up on yard waste recycling. Other recycling is marginal. The local dump has no place to drop off recyclables. You can drop off yard waste. They have a single garbage truck to put grass, leaves etc in. I asked the driver once, how many times do you have to empty this. He said that it won't get filled up in a day. And they are open only two days a week. What a difference in culture.
Lead-acid batteries are an obvious and very serious no-no for landfilling, as are the now somewhat old-fashioned nickel-cadmium rechargeables and silver oxide/zinc/mercury button cells used in hearing aids etc.
Lithium ion rechargables and even lithium primary batteries (non-rechargeable) are, in my opinion, very bad news to landfill, in the former case due to the cobalt and organic solvent content, and in the latter case due to the thionyl chloride used in the electrolyte.
But run of the mill Zn-Mn alkaline or zinc-carbon "heavy duty" batteries- the lion's share of the consumable/throwaway batteries in the marketplace, aren't really a huge problem in a landfill now that there is no mercury in their formulation. But if they can be collected, recycling them is a good idea from an environmental perspective relative to landfilling them.
https://haltonrecycles.wordpress.com/2012/10/25/tr...
Ni-metal hydride batteries are important to recycle because of their "rare earth" (lanthanide) content as well as the nickel. "Rare earths" aren't all that rare, but they're a total bear to separate from one another. The separation process takes a huge amount of energy and results in a lot of emissions, so recycling of these materials is quite an environmental benefit.
For Lead-Acid, many sellers will take them, and even some metal recyclers.
I was talking about substation batteries above.
Federal law in the United States holds the manufacturers responsible for providing facilities for the recycling of their batteries at end of life. That is batteries containing hazardous materials such as lead/acid batteries.
In particular substation and large DC power plant batteries, some of which have integral steel case housings or large jar lead/acid batteries go back to the original manufacturer due to special handling processing needed, beyond your average automotive battery recycler.
Federal law (via DOT regs) also regulates and holds originating shippers (identified on the Bill of Lading) responsible and subject to fines for the proper packaging and method of transport for batteries containing hazardous materials.
It is not uncommon for customers having these type batteries removed to require the company doing the removal to provide the paper audit trail of the transport and site where the batteries were recycled.
East Penn one of the majors that are located in the US http://www.eastpennmanufacturing.com/about/sustain... uses a completely sealed process to grind up, separate the component materials e.g. plastics, lead, acid and purify for re-use. http://www.eastpennmanufacturing.com/wp-content/up...
If I remember correctly Exide's recycling plant (for lead/acid batteries containing trace amounts of cadmium) is in Canada. Large scale stationary lead acid batteries used cadmium in the terminal components for some years.
TTFN (ta ta for now)
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
Hence we have collection bins in supermarkets etc
I think that your local province/state/country authorities must have rules in place for the safe disposal of batteries.
This weekend, I had to replace a battery in one of my vehicles. I bought the replacement at Costco (where else), and they take they took the old battery back for recycling (with no additional fee).
I live in the province of British Columbia, land of the $30/ton carbon tax, and I believe that battery recycling is a provincial responsibility. I have noticed that most stores in BC also have collection bins for all types of batteries.
I would recommend that you first investigate the requirements in your local jurisdiction to find out what is legally required wrt battery recycling, and take it from there. Good luck
GG
"I have not failed. I've just found 10,000 ways that won't work." Thomas Alva Edison (1847-1931)
Actually, in the US, Costco charges what's called a "core fee," which goes for recycling the battery you returned.
Costco BC also has the '$10 core-fee'. The $10 fee is reimbursed back to you when you bring in your old battery to Costco. Sorry, I should have said that the net fee is $0, at least at Costco BC. Sorry for the confusion.
GG
Keith Cress
"You measure the size of the accomplishment by the obstacles you had to overcome to reach your goals" -- Booker T. Washington
