electronic signatures
Hello all,
I am a Florida PE and have recently been informed by one of our clients that from now on, all the construction drawings have to be submitted electronically with electronic signatures (NOT digital facsimiles of the stamp and signature, but locked PDF files). I have read the FL rules and I think I understand the requirements but I am clueless as how get started. I read language about third party signature verification's and signature files with document list and encryption keys,.....
Does anyone know of a source for guidance on this?
RE: electronic signatures
https://helpx.adobe.com/search.html#q=sign%20%26%2...
TTFN (ta ta for now)
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
In a discussion I had with the FBPE's general counsel, he indicated that the Adobe Encryption process was not acceptable but was not clear on the reason. He indicated that it was not unique and verifiable....I disagree; however, they make the decisions and we must live with them until we work to get them changed!
Engineer's governed by lawyers!
Of course, if it is the case, convincing them to change it is another thing entirely. Its certainly very easy to get quite lost in how to manage electronic signatures.
Whether this meets all the requirements of Florida I don't know. On a recent Florida project we wet signed everything I think.
If you pay separately for an Adobe accredited signature certificate, then Acrobat will indicate that the signature is verified.
However, you're correct in the regard that document modifications should show up, regardless of what certificate is used.
Let's say someone simply copies and pastes your signature from a different pdf, or creates their own imitation electronic signature using similar software. The only way anyone can actually verify the signature is if someone calls you and asks if it is indeed valid. And as far as i know, electronic signatures can only be verified by the creator by checking against their private encryption key. And if it can only be verified by you, then you may as well just check your saved drawings on your computer or your sent emails to check whether the drawings are valid.
We tell our on going clients that the only verification we accept is an invoice for the job. If someone is willing to forge a signature then really nothing will stop them unless you somehow find out and tell the police.
So the encryption only serves to exonerate, or lay blame, on the EOR.
The overall intent of electronic signatures would be the same as keeping wet signed copies, and any changes to the fact would be able to be detected through a manual review. Its also entirely possible to electronically sign documents without a visible signature, thus there's no image to copy. This makes it harder when only issuing printed copies, but I suspect that most places will issue electronic documents anyway.
I've personally seen a couple of instances of fellow employees misrepresent approved documents, in these cases with a scanned signature image stored somewhere there's an internal risk, not just for 3rd parties altering records; and for this reason I've never used the cut and paste method on anything I'd approve.
As an aside, PDF used to be used instead of native document formats (such as MS Word) as it was perceived to be quite difficult to change compared to the native formats. Another forum member here noted that a client was easily able to edit their submitted PDF and change the results, thus some means of protection is likely a good idea.
It is possible to generate encryption checksums (e.g. MD5SUM) to verify whether a document has been altered (Linux distributions have been doing this for years) but the electronic signature is probably easier to implement, as the checksum has to be generated at document issue, and then stored for later comparison. It also doesn't replace the requirement of EOR or similar to approve the document.
I think most boards are going to this type of system.
