Max and Min RPM
Max and Min RPM
Hi all,
I need to use a fan. I have calculated the internal curve of my system. I saw fan suppliers websites and got the characteristic curve for a fan which works in my range of interest. All the fan curves which I saw are calculated for a certain RPM. So I calculated the fan curves for different RPMs with the fan laws, in such a way I can calculate different working points.
My problem is that I did not find any indication about max and min RPM for a certain fan. So my question is: is there any rule of thumb which would allow me to estimate the max and min rpm at which a fan can rotate?
Thanks so much
Thanks so much
RE: Max and Min RPM
Dejan IVANOVIC
Process Engineer, MSChE
