Steel plate on reinforce concrete wall subjected to lateral force
Hi guys,
I was wondering if you could provide me with any worked example in regard to design steel plate on reinforced concrete wall to resist the horizontal force..
I already designed the plate to resist the horizontal force, but I am not sure, when I need to design the wall and the base, do I need to consider the maximum moment induced by the horizontal force, or just use minimum reinforcement.
Many Thanks
Leo
Many Thanks
Leo
RE: Steel plate on reinforce concrete wall subjected to lateral force
So what is the point to have the steel plate if it would not reduce the force on the wall?
"provide me with any worked example in regard to design steel plate"....so you have not designed the plate?
"I already designed the plate"....so you have designed the plate?
Which is it?
"do I need to consider the maximum moment induced by the horizontal force".....YES
