No Step definition was found
So, i´m having a strange problem with Abaqus/ Cae.
I was working in my old computer since now, everything was ok.
Recently i moved to my new computer and was trying to perform some analysis but the same erros keep appearing - No step definition was found (see annex).
I save that work in a flash drive and i run it in my old computer - No problem.
RE: No Step definition was found
Is it similar for other models or only for this one?
When i perform simple models there is no problem.
When I start one complex model from scratch that error keeps appearing.
Just write out the input file, open it with a text editor and check if the step definition is in there.
But overall I have no idea what the reason could be.
