Middle Mouse Button refuses to rotate the model
I've recently installed NX11 on my laptop. Everything works fine, however I can't rotate or pan the model using the middle mouse button. I've gone out and bought a new mouse and that still doesn't solve it. NX acknowledges MB2 is pressed as it shows two concentric orange circles, however it does nothing. I have to use ctrl - R to rotate and that's horrendously clunky. I have a spacemouse on order however in the meantime I'm not very productive.
Any ideas?
Any ideas?
RE: Middle Mouse Button refuses to rotate the model
As an alternative (if the above doesn't work), you can use menu -> view -> operation -> rotate (shortcut: Ctrl + R); this will let you use the left mouse button to rotate.
www.nxjournaling.com
Thank you for your help anyway!
test 1)
open the mouse settings and verify that the middle mouse button is set to "middle mouse button".
test2)
uninstall the mouse driver completely.
- without this special driver , the windows default driver will kick in and probably make this mouse work as expected.
( any special buttons will not work)
Note, gaming mouses will most often work prefect with NX including their special driver, with the notation above.
I use one myself.
Tomas
