Siemens Licensing Help
We were sold 40+ licenses by our reseller with the understanding that we wanted all of our licenses on a centralized license server. Come to find out, as we're setting this server up, all users need to be on the same domain! (a Siemens license requirement) Well, we have users on three domains, and our network structure is by design... We have no plans to consolidate to one domain, and in fact, it was designed the way it is for a reason.
I'm wondering if anyone else has run into a similar problem (multiple domains & trying to use Flex licensing) and if so, what did you do to get around this technicality? We're not interested in doing cloud licensing as the whole point was to lower the total number of licenses by allowing them to float. Cloud licensing requires each user to have their own license.
RE: Siemens Licensing Help
If this still isn't working out for you, and if the distributor/vendor that you getting your software/support from is unwilling to help, please feel free to contact Siemens PLM directly or call GTAC at:
https://www.plm.automation.siemens.com/en_us/suppo...
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
If they are on unique domains to prevent cross-talk between systems, then you will have to work with your reseller to separate the quantity into 3 different sold-to IDs to be run on 3 different license servers. You'll only be able to float the licenses assigned to each server, so you do run the risk of having too many licenses on one server and not enough on another. Not an ideal situation, but probably as close as you can get if my assumptions are true.
FYI: Siemens typically charges a small fee for license transfers. So, if you ever find yourself with excess licenses on one server and short on another, you can transfer them without having to buy more seats. If you do have to split up your initial purchase, you should be able to negotiate a no-fee transfer this first time since your reseller didn't understand the requirements.
--Scott
www.wertel.pro
