Max Allowable Stress
Hi All Member
1. Actual stress(153.4 MPa) is same with max allowable stress(153.5 MPa). This result is acceptable as per ASME Code? - Vessel Design as per ASME Code.
2. Is necessary to reduce the actual stress?
RE: Max Allowable Stress
