Re-link more objects, features in a part of assembly
I have a question if is possible to do "mass" re-link objects, features etc. in NX 10 from a part to other.
For example:
I have a parts with names AAA_1 and AAA_2.
AAA_2 has many links to AAA_1 and I will change name of part AAA_1->AAA_1A.
Must I change every link separately or is there exists some function/command for this task.
I've tried Interpart Link Browser and Relations Browser and there is only edit function for each item...
Do you have any experiences with it?
Thanks for answer.
Jan
RE: Re-link more objects, features in a part of assembly
If you fully open all the affected parts in the NX session and do a "save-as" on the desired part, the links will be updated. Note that you will need to save the parts that link to the "saved as" part to keep the new link information.
www.nxjournaling.com
