Large diameter washers and hole+bolt sizes ?
Hi
What size large diameter washer can I use with which right hole+bolt combination without bending/deforming the large washer ?
I'm talking about those small hole washers that have large outside diameter and tend to bend/turn conical when used in too large holes...and wondering what is the right size washer+hole+bolt combination to use without deforming the washer ?
I have a bolt size 8mm and hole is 14mm so which washer size do I use 16mm or 24mm ?
RE: Large diameter washers and hole+bolt sizes ?
You are going to have to work this one out. Roark's has equations for flat round plates. You can figure out the screw torque and the washer size.
JHG
Take a look at the Belleville washers in the McMaster Carr catalogue. They have some serious, heavy duty ones, unfortunately, without technical specifications. I worked out their stresses and compression forces, and I found that they approximated the yield strength of the screws. This did not suit my purposes at the time, but I made a note of it. This could be useful sometime.
You will have to look them up and do the analysis, and you may have to use a torque wrench to assemble everything. This may solve your problem.
JHG
If you need something stronger, it will have to be custom.
It does not have to be expensive; it's possible to bang out a rectangular plate with a hole in it, in just a few seconds with an ironworker, provided that you don't use stupid tolerances.
Mike Halloran
Pembroke Pines, FL, USA
What is needed is a plate of the same thickness as the base plate the hole is in welded to the plate then droll a smaller hole.
Trying to fudge it with a washer is just asking for trouble IMHO. If you search for washer on this forum you find some interesting debates and lots of people mention asme PCC
I would just make a combination of bush and washer if you can't use bigger bolt.
- Company apparently has only M8 size screws ?
The extra depth of the lower T shape provides a lot more strength than a simple flat washer of variable strength.
There is no way you can accept having a flat plate / washer start to bend - you're then already at max force and any more force will get worse and worse as the bending continues.
are you saying you need the full 14 mm DIA holes to assemble the components ?
