Linking Abaqus 6.14-5 with Intel Parallel XE 2013 with VS 2010
I have been having trouble linking Abaqus with the compiler. I used the following tutorial to link the softwares:
https://www.youtube.com/watch?v=ImWUFZAKlr4.
I'm using Abaqus 6.14-5 with Intel Parallel XE 2013 with VS 2010. The UMAT code is:
SUBROUTINE UMAT(STRESS,STATEV,DDSDDE,SSE,SPD,SCD,
1 RPL,DDSDDT,DRPLDE,DRPLDT,
2 STRAN,DSTRAN,TIME,DTIME,TEMP,DTEMP,PREDEF,DPRED,CMNAME,
3 NDI,NSHR,NTENS,NSTATV,PROPS,NPROPS,COORDS,DROT,PNEWDT,
4 CELENT,DFGRD0,DFGRD1,NOEL,NPT,LAYER,KSPT,KSTEP,KINC)
C
INCLUDE 'ABA_PARAM.INC'
C
CHARACTER*80 CMNAME
DIMENSION STRESS(NTENS),STATEV(NSTATV),
1 DDSDDE(NTENS,NTENS),DDSDDT(NTENS),DRPLDE(NTENS),
2 STRAN(NTENS),DSTRAN(NTENS),TIME(2),PREDEF(1),DPRED(1),
3 PROPS(NPROPS),COORDS(3),DROT(3,3),DFGRD0(3,3),DFGRD1(3,3),
4 JSTEP(4)
C ELASTIC USER ROUTINE
PARAMETER (ONE=1.0D0, TWO=2.0D0)
E=PROPS(1)
ANU=PROPS(2)
ALAMBDA=E*ANU/(ONE+ANU)/(ONE-TWO*ANU)
AMU=E/(ONE+ANU)/2
DO I=1,NTENS
DO J=1,NTENS
DDSDDE(I,J)=0.0D0
ENDDO
ENDDO
DDSDDE(1,1)=(ALAMBDA+TWO+AMU)
DDSDDE(2,2)=(ALAMBDA+TWO+AMU)
DDSDDE(3,3)=(ALAMBDA+TWO+AMU)
DDSDDE(4,4)=AMU
DDSDDE(5,5)=AMU
DDSDDE(6,6)=AMU
DDSDDE(1,2)=ALAMBDA
DDSDDE(1,3)=ALAMBDA
DDSDDE(2,3)=ALAMBDA
DDSDDE(2,1)=ALAMBDA
DDSDDE(3,1)=ALAMBDA
DDSDDE(3,2)=ALAMBDA
DO I=1,NTENS
DO J=1,NTENS
STRESS(I)=STRESS(I)+DDSDDE(I,J)+DSTRAN(J)
ENDDO
ENDDO
RETURN
END
The error message is shown below:
Abaqus 6.14-5
Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 14.0.0.103 Build 20130728
UMAT.for(14): error #5082: Syntax error, found IDENTIFIER 'JSTEP' when expecting one of: , <END-OF-STATEMENT> ;
4 JSTEP(4)
compilation aborted for UMAT.for (code 1)
Abaqus Error: Problem during compilation - C:\Users\labcfg\Downloads\UMAT.for
Abaqus/Analysis exited with errors
Can you please help me figuring out if? my UMAT file is wrong or the compilation is the problem
RE: Linking Abaqus 6.14-5 with Intel Parallel XE 2013 with VS 2010
You can run the verification process (Abaqus Installation and Licensing Guide - Appendix D: Verification procedure)
or use a predefined example from the Verification Manual to check your infrastructure.
It looks like your UMAT is wrong, to be more precise FORTRAN does not like line 14 "4 JSTEP(4)".
If you compare your UMAT arguments with documentation you will find a mistake. One before the last argumnent is JSTEP not KSTEP.
CODE
     4 CELENT,DFGRD0,DFGRD1,NOEL,NPT,LAYER,KSPT,JSTEP,KINC)
Bartosz
VIM filetype plugin for Abaqus
https://github.com/gradzikb/vim-abaqus
@akabarten We use that code for 6.14 and KSTEP for 6.13.
@Mustaine3 We verified it but the std.out says that the license is expired which is not the case because we just got it. Do you have any video tutorial or documentation you recommend
