Balloon Annotation
Balloon Annotation
When attaching a balloon I get the following (see attachment)
The start of the balloon line is somewhere on an extentenden line off the selected line ?
I'd like the arrow on the position where I selected the line.
Attachment is made in NX10.0.3.5 MP10 native
Kind regards,
Lars
Kind regards,
Lars
Lars
NX10.0.3.5 native
Solid Edge
Inventor
RE: Balloon Annotation
I found it easiest to just manually advance the menu.
Under the "Leader" pull down within the "Balloon menu. Click "Select Terminating Object" prior to selecting the item you want the leader to terminate at, this will stop that annoying drag line.
I can't wait for this item to be addressed.
If I understand correctly this has to be done with every balloon you want to manually place ?
Lars
NX10.0.3.5 native
Solid Edge
Inventor
If anyone knows of a way to alter the default condition of the balloon menu, please share it.
I admit that the interaction needs some "special touch", but here's how it works:
1) Click balloon feature ( open dialog to create the balloon.)
2) position the cursor on the line you want the arrow on
3) press MB1 and drag mouse away from line, -as long as MB1 is pressed the arrow will slide along the line
as soon as you release MB1( but no-click) the arrow will stop sliding but the balloon still dragging.
4) If you like to slide the arrow more along the line, press the shift key and continue move the cursor.
5) click MB1 to place the ballon.
When you are moving a balloon, without opening any dialog, Position the cursor on top, press MB1 and drag.
If you combine the drag with shift key, it will again slide along the selected object.
Tomas
Thnx for the response. I've been using your method. The problem is that when selecting a line of a component the arrow sort of slips away on an extension line. See the pic in the first message.
So when i'm in you step 2 the extension line is created an the arrow is positioned on this line instead of the position I was
"clicking"
Lars
Lars
NX10.0.3.5 native
Solid Edge
Inventor
Will the "drag with Shift key pressed" move the arrow back to the desired position ?
Is this happening in all your files or is it just this one ?
Tomas
That is the behavior I would like to be able to control. When I select a component I tend to select it where I want the arrow to terminate.
The easiest solution for me, is to click the "select terminating point" prior to selecting the component.
but if you learn to release quickly after selection the arrow will stay close to the selected position...?
I guess that the enhancement to be able to use the Shift key to slide the arrow somewhat counteracts the enhancement.
Tomas
