Horsepower calculation of engine
what is the proper methodology to find minimum engine horsepower requirement to move x amount of load efficiently by forklift? For example if I want to build forklift which can lift 30000 pounds with 3 stage vertical mast lift, what would be the minimum horsepower requirement of engine that forklift can operate smoothly.
RE: Horsepower calculation of engine
Mike Halloran
Pembroke Pines, FL, USA
Hopefully that helps!
"Formal education is a weapon, whose effect depends on who holds it in his hands and at whom it is aimed." ~ Joseph Stalin
As ever with questions of this type the obvious thing to do is to have a look at what commercially available machines can do with regard to lift time and horsepower.
I used to occasionally drive various forklifts of about this size (30,000lbs) and certainly I would be generous with horsepower if designing one - when you are actually working with a big lifter the lift time and even the time taken to shift from forward to reverse etc. it becomes very important that it is as quick as practically possible.
Surely you are not considering building your own lift?
@BigClive, That was good one if you are joking and I would just say 'NO' if it was in serious tone. Honestly, I am trying to understand as I always have what? why? when? how? I am going through lot of material but very often I figure out that when we discuss, things become easy to understand.
I have couple of more question related to my initial post. Lets say if I replace my current engine which is having 100 hp @2200 rpm, torque of 289@/1400 rpm with power of 75 hp @ 2000 rpm and torque of 312 nm @ 1500. What automobile loose and what gain? I can see power is decreasing, torque increasing and rpm decreasing at max power, but I would like understand in broad manner.
If I pick the transmission with specification of speeds 1st = 2.9 mph , 2nd = 4.7 mph, and use v= v0 + at to calculate F=ma. Is it correct method to find initial speed v0 and thus acceleration(a).
Please, correct me if I am wrong. I would like to check and compare force available at wheel, speed and acceleration when engine is changed.
Suggestions, corrections and other opinions pleas.
There are a number of ways to calculate the acceleration. You can get a reasonable estimate by assuming a constant torque in each gear then using the constant acceleration formulae you have quoted.
je suis charlie
