nx cam 11 - zlevel profile with finishing pass..
Hi Guys,
sorry if this is a silly question but the zlevel profile op is very quick and easy to use. However it would be great if you could set finishing passes - I can't see how to do this. If not what is the easiest alternative or method to remove stock from an external part wall.
I have been cavity milling and setting trim boundries to create the tool path and adding finishing passes which is very nice but takes a little bit longer to set up...
many thanks for thoughts, insight and suggestions on how to think about this.
cheers,
james
cheers,
james
RE: nx cam 11 - zlevel profile with finishing pass..
Mark Rief
NX CAM Customer Success
Siemens PLM Software
