NX 10 Swap drawing template OR move parts list
I am updating an older drawing of ours and some how the template for the drawing disappeared or was linked incorrectly. All the information is correct i.e. title block, notes, revision history but the background borders are missing. How can I swap templates?
On other drawings, I used to fix this by creating a new sheet and moving all the views etc, to that sheet then deleting the broken sheet. For this sheet, that will not work because I cannot figure out how to move the parts list to the new sheet.
Thanks.
RE: NX 10 Swap drawing template OR move parts list
Have tried file import part. Then select your template prt file?
That worked. Thanks!
