How to keep a CO2 cartridge from freezing up
How do I keep a 12g CO2 cartridge (like the ones used in BB guns)from freezing up (forming dry ice) when I puncture it?
I need to be able to expel the gas over a time period of 10 to 20 seconds.
I am sure the experts here will want more information but as this is a subject matter I don't have much experience in I am not sure what information to supply.
Any help is greatly appreciated.
RE: How to keep a CO2 cartridge from freezing up
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
As I understand it, if i assume the worst case then the CO2 will be super critical (all vapor) but when I puncture the cylinder the cooling effect is so strong that the temperature is dropping faster than the pressure is.
That is an interesting idea I had not considered. I did wonder if orientation would make a difference but hadn't considered that being a good thing.
I am going to go try it now.
Is this throttling the saturated liquid? What does this do other than get more mass out of the cartridge faster?
My system doesn't really have an expansion "valve", it just expands into a larger volume container where is it used to push extinguishing agent out.
If the CO2 is still liquid after exiting the capillary tube would it not just convert to a gas due to being at a lower pressure? I am trying not to ask the question because I should probably already know...... but why does the CO2 need to be fully vaporized before reaching any expansion valve?
