A coming engineering shortage ? ---- Who agrees ?
A recent article says that there will be an acute shortage ... particularly in the electrical field !!!
http://www.csemag.com/single-article/the-coming-en...
Who agrees ???
Who strongly disagrees ???
MJCronin
Sr. Process Engineer
RE: A coming engineering shortage ? ---- Who agrees ?
Mike Halloran
Pembroke Pines, FL, USA
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
People with engineering degrees: No shortage
Experienced engineers with deep and confident knowledge of their field: Few and far between
As a young engineer working for a small town manufacturer, I'm not sure I'll ever make it to the second category.
There is a shortage of power engineers, and schools teaching electrical power.
I'm not sure this applies to mechanical engineers, as so few of us know what you do.
The big issue is the 25% over 55 bit. Given the state of most people's retirement savings, it's highly likely that most of these people won't retire unless they can get Social Security maxed out, which would be at 66+, which is more than 12 yrs away for the youngest of that group, and that age is expected to shift further out to 67+ for those born after 1960. And these people would have never all left at the same time.
Conclusion: much ado about little.
TTFN (ta ta for now)
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
We see these dire warnings continuously- even during recessions. The shortage is seldom claimed to be current- it's usually just around the corner. Soon enough to be worrisome, but far enough away that current measurements of employment levels, wages etc. are deemed to be irrelevant to the discussion about whether or not it's a real problem. Sometimes, it's a current shortage of mid-level people in some cyclic industry which completely stops hiring young people during every down-turn in the economy, which is then generalized to the entire engineering profession... For instance, I can predict with 100% certainty that the oil and gas industry will be screaming "shortage" the next time oil prices rise. All the people they're laying off right now, and the tens of thousands they laid off this past year, will have moved on to other things, retired, or be so far from their oil and gas past that they wouldn't be considered eligible for re-employment.
It has been happening like this for at least sixty years.
Google "IEEE Spectrum STEM crisis is a myth" and read that paper. He does the research and shows the pattern.
Why devote time to training when we are already behind schedule, over budget, and understaffed? ;)
FoxRox,
Not much is changing in the power industry as people make it out to be. There really is not that much that is "cutting edge" at least in comparison to other industries. No one is going to magically figure out a better way to transmit power over transmission lines. Yeah, super conductors are being used or proposed but those are for odd applications like where space is an issue in NYC or for a super substation like Tres Amigas that will connect the Eastern,Western, and Ercot interconnects together to allow wind generation in the midwest flow more freely. Bus protocols like 61850 will change how the substations wired, and tested but the general relay protection philosophies will very likely be the same. Protection philosophies have not changed much even in the move from mechanical to electronic relays. Power electronic devices are used but in very limited applications. The biggest change that I see is the amount and type of green energy being connected to the grid. A lot of upgrades and changes will also need to be made when electrical cars become prevalent. Depending on how slowly the car charges, it will increase the household kwh draw by mutiple, I think in the 2-5 range, during charging.
Compliance to NERC regulation is becoming a cottage industry in of itself. I don't know. I like it because there are a lot of nooks and crannies and when you pull out 40-100 year old text, almost all that you read is still relevant. With that, experience is always valued as opposed to in the .COM industry where fresh grads sometimes are valued over people who have been in the industry for a long time due to them having experience with whatever the new programming language is. Nobody is putting power engineers with 30+ years of experience out to the pasture. It is a mature industry that in my opinion shouldn't be using something like smart grid (too often a solution without a problem) to convince fresh grads that the field is becoming "livelier". It should be instead sold on the merits of being a mature industry with an old and huge 100 year knowledge base that is all still relevant and will never become obsolete.
I can't tell you how many sleepless nights I've suffered through.
no shortage of engineers, not many stick with it
However, your anecdotal observation of the students you interview runs contrary to the measurements. Our local engineering regulator PEO has been surveying substantial numbers of 4th year engineering students each year for quite a few years, and the results are consistent: over 90% of the graduates will either definitely or probably seek a career in engineering. Only about 6-10% know in 4th year that they are going to pursue something else, i.e. medicine, law etc. So that leaves about 60% of the graduating class, ending up doing something else by default, not by choice. And after a few years out of engineering, they're considered "spoiled" and not suitable for re-use. They've lost their profession for good.
Why do so many fail to gain entrance to the profession? Too few employers are willing to take them on and train them. They expect to find people with 10 yrs of relevant experience gained elsewhere, who can hit the ground running. That only works a) during recessions or b) if you offer significant salary premium. People who build their businesses on that kind of growth model SHOULD find themselves with a shortage of candidates in my opinion- they're shortchanging not only themselves, but the whole profession.
I used to count sand. Now I don't count at all.
Electric utilities have been hiring EE's without power background as a way to keep up with the need. This requires companies to do internal training on the power system.
The attraction of the utility industry is stability, so we see more people tired of the high tech job jumping. However, the background in high tech typically does not translate well.
It is true that many companies don't do much training, and some of that is a management problem, but smaller companies can't justify the staffing to train new people (Utility commissions pressure companies to keep staff low). But the NERC pressure is requiring more engineers with understanding of the issues, as well as staffing of regional groups, and new industries entering the power field.
There's some attrition out of the profession to SNORGY's favourite MBA route, for sure. That shows up in the numbers- a somewhat larger % of eng grads are employed as engineers 0-10 yrs post grad than in the upper years of experience. Some of that attrition though occurs when people are let go from a cyclic industry and not picked up as engineers thereafter- that too happens.
Maui
It proves the old saying" the people with a B average work for the government, and the people with the A average work for the people with a C average".
Take one guess why some people are so eager to bump up the supply of engineers.
Teachers in Ontario are reasonably well paid, although engineers don't get the summer off.
Anatomy of an Ontario teacher’s paycheque .
Remember of course, that these are Canadian dollars.
JHG
My question is simply this: IF we feel as a society that a teacher is worth their (equivalent of, once holidays are compensated for) $100,000 CDN/yr PLUS excellent benefits (the best defined benefit pension plan in the country- even federal employees don't have it that good!), is a similarly experienced engineer not worth more than that? The market at the moment says "no", as evident from the salaries of engineers relative to teachers, but ONLY because teachers are unionized and engineers for the most part are not.
Sanika Patel
http://crbtech.in/CAD-CAM-Training/
So from that a point of view, it might be better for us to import as many engineers as possible.
I also propose that there will be enough engineering grads that just can't cut it, and will become teachers.
http://www.thenewsminute.com/lives/609
And there are tons of articles about industry screaming how inadequate fresh graduates and that is why they hire only a small fraction:
http://timesofindia.indiatimes.com/city/mumbai/Onl...
http://www.wsj.com/articles/SB10001424052748703515...
Same stuff as in the states. Fresh grads suck. Nevermind that they need training. Only a fraction of fresh grads go into engineering. Wages are stagnate despite industry's cry that there is a shortage. I am not really convinced the quality anywhere is affected that much by workers leaving to work abroad. The glut is too large for quality or wages to be affected much by people leaving the country in my opinion.
But there also seems to be a shortage of quality power engineers. And Tech.'s, and Linemen, and truck drivers.
For that matter, there is a shortage of quality people available.
That's because they're already gainfully employed. The big question is whether we're at the point where any further increases in supply of quality people will drastically drop labor rates, because not every job requires the "best" candidate. Someone who is "good enough" will undercut the salary rates.
In some respects, all this emphasis on driving people into STEM is a lot like an external market manipulation, which we all know has potentially deleterious consequences.
Don't you think that if US will import cheap engineers, the quality of engineers in other parts of the world will actually increase?
There is an entire generation which is under-represented in power engineering - the one I'm part of. It's the 30-year harvest from the seeds sown during the privatisation (read: decimation) of the state-owned utilities in the 1980's and the recession of the late 80's and early 90's. Recruitment and training pretty much stopped for two decades before the power industry started to wake up and realise that a serious problem was developing, with the result that my generation is largely missing from an industry still dominated by the 'grey haired guys' who survived the huge cull. During that period many universities closed their unpopular power engineering classes because they were (rightly) seen by students as difficult, old-fashioned, and with lousy employment prospects, while the universities saw them as space-hungry, capital-intensive, minority-interest subjects.
Today a handful of universities have re-established first-rate power engineering schools and there are some really bright prospects coming out of these universities who will be excellent engineers once they gain industry experience, but they can't pick up two or three decades worth of experience overnight, and the old-timers are retiring faster than these new folks are gaining experience. I see this going on for another decade, maybe fifteen years or so until some sort of balance between supply and demand is restored. At that point I'll be getting worried that some of these new grads will be a lot better at this stuff than I am.
Whilst the situation regarding engineers may be improving in the UK these new graduates will be entering an industry where the critical path for distribution projects is dictated by the availability of cable jointers. The bigger skills shortage in my opinion is of craftsmen in trades which most people do not even know exist.
Truck driving skills is not a problem.
It's the power engineers, INC tech's and relay tech's we have difficulty finding.
I suspect some trucking companies do play games with employees.
My comment was about the skills not the people willing to do the job. Besides utility trucks, in general, are not that big.
We do have special people for driving oil rigs, and other larger things. But in general the line trucks have to be able to go over city streets, and dirt roads.
Yes, I agree there are chronic shortages of jointers, also protection engineers, TP141 commissioning techs... the list goes on.
Managers are ten-a-penny though!
I believe so - even without being away from home for long periods of time some of the pay rates weren't impressive.
If you are hiring truck drivers at minimum wage, you are likely to have shortages.
Paying engineers more will increase the pool of engineers, but it will take time to train them, and weed out the bad ones.
So from that perspective, there should be no shortage of engineers. Just a shortage of companies who are willing to pay a reasonable rate.
Which brings to mind how so many companies are not willing to pay their in housh engineers more, but are willing to hire consultants at three times the rate, for second class work.
You may be onto something there.
Given the overhead multipliers in most large companies, paying only 3 times as much money for work which is only 2nd class would be seen as excellent value for money!
Having an in-house engineer means more than just the sheer cost, you have to feed that one guy stuff that he's interested in doing, and if you don't do that, at best, the guy gets rusty over time, and at worst, he bails after a couple of yrs of fixing stupid crap that the cheap engineer should be able to fix, but can't. This also means that your cost to maintain in-house capability goes up even further if you have to pay for acquisition of the next qualified engineer, in head-hunter fees, advertising, and down time to interview candidates.
There are certain disciplines that we've been completely unable to fill because of the reasons above.
Generally.
On multipliers; we charge junior staff at a higher x, than the senior one.
8k a month in San Francisco is like 4-5k a on a month in a lot of other places. If you look up BART salaries, there are plenty of "uneducated" people breaking 100k. I have a relative that worked closely with CEO Marissa Mayer at Yahoo and he still needed a lot of help from his parents to buy a house.
But, bear in mind that the $8k for the intern is in ADDITION to:
> free housing, but shared with a couple of other interns
> 3 meals a day during work week
> free transpo to/from work to the free housing
For a junior in college, that's a exceptionally sweet deal, and, that's increased from 3 years ago when the intern salary was $6k/month.
A detailed, well-documented study of the engineering labour market in Canada, in Ontario in particular, based on solid census data and other similar sources:
https://www.ospe.on.ca/public/documents/advocacy/2...
The conclusions, in brief:
- only 31% of engineering grads in Canada work as engineers or engineering managers. It is the lowest match rate between education and work placement of any of the country's regulated professions
- the lines of the number of engineering grads (supply) and the number of engineering jobs (demand) have different slopes, and have diverged steadily over the past two decades
- a larger fraction (33%) of engineering grads work in jobs not requiring a university degree of any kind. That alone is clear evidence of a massive under-employment situation for engineering grads in Canada
- the 69% working outside engineering, earn on average 20% less than the 31% who do, so if they've left the profession voluntarily they've done so against their economic interests
- 92% of engineering 4th yr students surveyed indicated that they definitely or probably will pursue a career in engineering- obviously, many fresh grads are unable to find work and hence lose their chosen profession rather than choosing to abandon engineering
Another well documented study, indicating a systemic pattern of predictions of future STEM shortages that has happened since the 1940s:
http://www.theatlantic.com/education/archive/2014/...
http://spectrum.ieee.org/at-work/education/the-ste...
FTFY
" Engineers imported from overseas as Australians struggle to find jobs "
http://www.theage.com.au/business/workplace-relati...
High responsibility
High Stress
High visibility
Low / Slow upward movement
Low respect
Med pay
I'm really getting tired of it. I'm pretty much ready to move on. Maybe I'm a 'B' engineer, but I feel like there is only one person on our engineering team better than myself. Who knows. I'm tired of fighting all the time, tired of every team pushing me to make 'easier' decisions for mfg, cost and time. Tired of building Bill of Materials. Tired of B / C engineers asking me simple problem solving questions. And I hate how software knowledge is more important than knowledge. Some person knows how to run CFD and Ansys and his resume is gold. Same guy doesn't know what to do when the customer asks him about clearances without running a stupid 3D software. Why didn't engineers divorce themselves from 3D software? Just contract it out. I don't care how to make the grid to do this or do that. I need to know what the stress is here. Make it happen.
I guess you can tell that I'm over the whole thing.
As to pay, clerical engineering is not well paid. Neither is clerical banking.
Cheers
Greg Locock
Tunalover
What- languages aren't important? Or the social sciences? Or economics?
There is no STEM shortage nor any shortage of kids interested in pursuing STEM careers. There is a persistent shortage of employers willing to take on fresh graduates and train them. That shortage results in a shortage of people at the putative "peak" return on investment for an employer, i.e. someone with ten- not two or thirty- years of relevant experience gained at someone else's expense. These employees will be in perpetual short supply if employers don't realize that professionals need to be built from good raw materials, not purchased like widgets off a shelf.
awhicker84: I hear you. I get tired of people telling me what a good gig engineering is. The risk and stress to reward ratio for the average engineer is terrible. We have allowed our profession to be commodified, primarily by selling our services by the hour rather than getting paid for the value we create by embodying our engineering in products which we sell. When all you sell is man-hours, all engineers are reduced to equivalent billing units and subject to hourly price competition, tempting employers to stuff cubicles with billing units of questionable virtue in order to get ahead. We find it's far easier to be compensated in accordance with the value we create if we forget about selling man-hours and instead make a product which embodies our engineering and sell that. It's also a hell of a lot more rewarding.
Reaction to change doesn't stop it
We engineers instead went the other way- we were licensed for eighty years before we founded an advocacy body, used the excuse of not having one to not do ANY advocacy on behalf of professional engineers because doing so would be somehow a conflict of interest...and eroded our own restricted realms of practice by permitting an industrial exemption from licensure and a Certificate of Authorization program to permit corporations to do professional engineering in their own name (i.e. what can amount to one signatory engineer taking responsibility for the work, with a crowd of non-engineers doing the actual work).
The median salary for a level D engineer is the same as that for a teacher here in the province, once you account for all the extra vacation the teachers get. And we're not done our race to the bottom yet- we keep on digging...
And yet, in California, where there is an industrial exemption, engineers at Alphabet got high 6-figure salaries and most engineers in Silicon Valley do very well. This argument continues to come up, yet, for someone like me, who NEVER sees the public, NEVER works on anything that impinges on public safety, there's this harping to get licensure. But for what? Ultimately, we still get sold by the pound, because that's the way contracts are set up. But, my pay is fine as is the pay of all the engineers in the company, so what rationale is there for licensure?
For "ordinary" mortals, internships last year were priced at effectively $96 k/annum; this was for college students still in school. Starting salaries were probably on the order of $120 k.
My point is simply this: engineers here in Ontario, within living memory, earned more than either doctors and lawyers. We now earn a fraction of what those professions earn in median terms- in fact we're now on par with teachers in terms of pay. It's very clear WHY that reversal happened here- we allowed our profession to become a commodity, whereas the other professions didn't. Teachers unionized- so did the doctors, though they don't call their union a union. Lawyers didn't unionize, but they didn't allow law firms to practice law in their own name- they permit partnerships but don't grant licenses to corporations to practice law in their own names using armies of paralegals, for instance. There is no exemption from licensure for the practice of law, period- lawyers are very good at making rules which ensure there is always a job for lawyers. They also are still the most prominent profession in politics.
Right now even the requirement for 1 yr of experience mentored by a licencee prior to licensure (so the licensee at least has a chance to determine if the person actually understands the legal and ethical requirements of licensure) is under attack as contrary to the human rights of immigrant engineers. So the trend is for even more supply. The prospects for a demand-side solution to falling engineering wages are basically zero. With the profession only able to "capture" less than half of its own graduates, it's tough to see how things could get worse, but we're trying our best. I'm sure if we maintain a sufficiently positive attitude about what a great gig it is to be an engineer, and how there are always shortages of engineers, and how well engineers are paid, we'll be successful.
Agreed. One approach that has been suggested however is a Grad degree as a minimum for licensure. I've never agreed with the idea, but I guess it actually would cut down on the supply.
Companies sometimes will assign a young engineer primarily with repetitive and dull responsibilities that don't grow their skillset. Once you kill a guy's enthusiasm, it won't come back as strongly ever again. Throw the young guys in the mix enough to keep them engaged and challenged.
"Formal education is a weapon, whose effect depends on who holds it in his hands and at whom it is aimed." ~ Joseph Stalin
THIS pretty much tells you that we're in an over supply condition that's unlikely to change. While a graduate degree could potentially drive down the supply, I doubt that there will be much impact. In my high school years, taking 3 AP classes was considered to be high achieving, and there was no IB whatsoever. Today's high schoolers, in the college prep pathway, take at least 12 AP classes, and many take an additional 7 IB exams. With an appropriate selection of such classes, and a firm and early decision of a major, finishing college in 3 years is achievable, so adding another year for an MS simply brings you back to 4 years of college, total.
Earlier there was a comment about CS not being engineering; UC Berkeley's College of Engineering's CS degree is EE-CS (they call it "eeks"), i.e., electrical engineering/computer science, so for them, CS is an engineering degree and discipline, and graduates have to fulfill the requirements of an engineering degree.
It's one thing to raise the bar because you actually need the extra skills etc. you get from a Masters, using it to crudely prune the supply side is very questionable in my view.
One aspect to the 'shortage' that I saw alluded to in an article a while back is that some very capable students in STEM perceive that it's harder for them to keep their grades up than their colleagues in some other subjects so they transfer. I forget if they followed this as far as checking that with these other degrees they get similar employment opportunities & ROI etc. One might argue this could be a good thing that the people staying in STEM are more engaged & enthusiastic etc. even if not always as academically gifted. Or, one might be concerned that many of the 'brightest & best' are leaving STEM education for paths they see as giving better reward for investment.
Not to fear though if the 'native' STEM Phd candidates drop out to go basket weaving or work on wall street, we'll fill the Phd programs with imported talent (some of it not particularly exceptional) and skirt the H1B limits because student visas can be transferred to H1B without counting against the quota. Then our vaunted tech industry will have all the indentured servants it can handle.
(Sorry, may be a little grumpy today so take with a pinch of salt as needed.)
Engineering as a whole could certainly have a glut while the power industry and other niche fields like programming have a shortage. Lucky for them.
As a Mechanical Engineer (BSME), I certainly feel like this is the case. When I graduated five years ago, I had a gut feeling that the piece of paper I received was a dime a dozen.
That being said, I still think there is a chance for superior talent and work ethic (hoping that I have both in sufficient supply) to prevail over a glut of degree holders. It's interesting to discuss the topic, but as an individual it does no good to blame immigrants, government policies, or our engineering forebears for one's own plight.
At this point I often joke that, if I had it to do over, I would have been a dentist or a dermatologist. Work half the time for ten times the pay. Alas, who can predict what the perfect job would look like in their future self's eyes?
an age-gap at some point in the past"I mean, it's not like the ageing process and typical retirement ages etc. are so unpredictable that it's a meaningful excuse.
That being said, many universities don't teach electric power. That maybe because teaching pays so much less than the actual industry.
I am assuming teaching other areas of engineering pays closer to the industry wages.
The other side of it is for a long time microelectronics engineering has paid so much better than power engineering, likely to the point there were very few people going into the power option.
There's just not that much demand for courses. If there were demand, there'd be professors hired to do the teaching.
The top 10% of engineers can still thrive. But the notion of a BASc being a meal ticket are long, long gone.
The lack of growth in salaries has occurred over decades, and is relative to other professions subject to the same global economic pressures, the same recessions etc. The slide hasn't happened because of recessions- it has happened because we allowed the supply to swamp the demand. And if we keep up this attitude of limitless opportunity in engineering, I'm confident that we can make matters even worse. Every Dean of Engineering in Canada seems to be positively brimming with that positive attitude.
So are you saying that boring industries will in the future go wanting for engineers, while exciting industries will be swimming in engineers?
Sounds like some industries will be seeing wage freezes.
The premium for power engineers will be so high that it should eventually lead to increase in supply. The premium for courses in power engineering and people to teach it should likewise grow...
Now it's not the smoothest of systems and hits a lot of bumps and snags along the way but in theory should get us there barring gross negligence/self serving etc. at management and government levels and the like.
So we're probably attached to another object by an inclined plane, wrapped helically around an axis.
That's mostly true, even outside of engineering. Why is psychology one of the most popular majors in college when the typical graduate winds up in a $35k/yr job as a social worker? Was that really worth borrowing a quarter million that can't be paid off with that kind of salary?
Physics 1 used to be a "weeder" class in my school, because the school knew that the plethora of wannabe physicists wouldn't be able to get jobs at the end of the 4 yrs. Of course, the class was so brutal that my roommate declared for Eng. Lit. at the end of that, and that was in a serious engineering school. But, even at the worst, he only paid a total of about $20k tuition in then-year dollars. Even the worst student could expect a loan to salary ratio of 1:1, while currently, it would be more like 2:1 to 4:1, unless you go to a state school.
The industry will make due. Over standardization and knowing how to use software has been given more weight than understanding. It will just be more bloated and dumber. Utilities are regulated ,too, so the wages are never tied to demand. Unionized master techs are better off than nonunion engineers.
Medical Engineering
(http://www.dimolanka.com/sectors/sector-overview?s...)
Link
Medical Engineering
Any engineer should be able to look at that graph and understand in an instant what is really going on.
Sure, it will. That is the basis of supply-side economics, the "if you build it, people will buy it" theory that's been PROVEN time and again to not work, but because it's derived from political dogma, they continue to spout it ad nauseum. A very casual analysis of wage growth vs. wealth of the top 1% vs. corporate profits shows very clearly who really benefits from supply side economics and it certainly ain't us. Minimum wage in the US in adjusted dollars was growing up until supply-side economics was pushed into the mainstream of American politics, and lo and behold, it has DECREASED 40% since its peak in the 1970s. And yet, the top 1% has seen an order of magnitude increase in wealth over the same time frame. Is that a simple coincidence?
If you ever wanted to see a real-life global-scale conspiracy, this might be it.
I think it goes without argument that the overall rates of college graduates is rising overall in my own country (USA) as we continue to pressure everyone to "get a degree, any degree, just get a degree because everyone should" which results in a lot of irrelevant education with their future employment.
At the risk of taking the thread off course......with respect, that is tying a lot of things together that are not necessarily related. Wage growth doesn't really have much to do with tax policy. That is just redistribution after the fact. You can tax the highest wage earners all you want.....and unless the revenues are redistributed later.....it's meaningless. Wages are a direct result of supply and demand, production being increasingly automated, etc, etc.
As far as supply-side goes......whatever its flaws, it was intended as a response to the collapse of the Keynesian school models that went up in flames in the 1970's. (With the coexistence of high inflation and high employment which supposedly was impossible in the Keynesian school.) It also coincided with the entrepreneur revolution of the 80's. (I.e. a need for incentive as productivity declined in the 70's.) It certainly isn't the cure-all the a lot of right-wingers make it out to be (principally because they mismanage the budget aspect of it: i.e. not accounting for a initial slide in revenues). But you'd be hard pressed to find many economists who want the old tax code back. (Even Jonathan Chait admitted this in his book slamming supply-side.)
Another aspect might be that not all the engineering universities are the same, and some of the degrees are given to people who may not be qualified, or go into management, or both.
And yet some in political office still follow the Keynesian theory.
Yet some of the richest people never finished college.
I don't know that the two are connected. The idea that is being hinted at here is that if taxes were higher that would mean more for other classes. (I.e. that somehow employers would give their employees more (presumably to avoid taxation).) And that just isn't the case.
That is, unless the money was redistributed after the fact. On that note, in the era of super high marginal rates (70-90% +) that isn't what happened with revenues anyway (i.e. income redistribution in the form of benefits such as heath care). Defense spending (to name one) was much higher.
I don't think there's been any evidence given for that claim. Certainly, for most serious, college-bound students, that's definitely NOT the case. When I went to college, back in the dim past, 3 AP classes was above the norm. My high school senior is currently gearing up for his 10th through 14th AP exams. If his competitors were really that poor, there would be no need to stack that many AP classes and exams to be competitive. And even with 9 AP exams with 4s and 5s under his belt, he's barely competitive with his peers.
@JNieman: here are two figures:
1) Intentions of 4th year engineering students in Ontario, surveyed by Ipsos-Reid on behalf of Professional Engineers Ontario. These surveys have shown results which are consistent through numerous years in which this survey has been completed.
2) Table 1: Match rates between education and employment in all the regulated professions in Ontario, from the 2006 Survey of Households. The 2011 Survey of Households, derived from the long-form census, was destroyed by our former Tory government, deliberately- they found it easier to hold ideologically-based positions when there was no pesky data to contradict them. The current government has fixed that for subsequent years, but the destroyed 2011 census will haunt us for years to come.
A few points:
1) Engineering students in 4th year overwhelmingly want to work as engineers.
2) Over twice as many engineering graduates work outside the engineering profession as work within it. In fact, about 33% of engineering graduates in Canada work in areas of employment for which a university degree of any kind, much less an engineering degree, is not required. That's a larger proportion than the ~ 30% of eng grads who work as enginers
3) The ~70% of engineering grads who work outside the profession, earn on average about 20% less than the ~ 30% who work as engineers or engineering managers
4) The match rate between education and employment for engineering is the lowest of all the regulated professions in the country, and not by a small margin.
The match rate decreases with years of experience, as we all know some people previously employed as engineers who leave the profession either by default or by choice. That fraction is also affected by the influence of immigration: while the situation for engineering grads in Canada in composite is bad, the situation for those Canadian engineers who were educated outside Canada is even worse- of that group, only ~19% work within the profession.
All this adds up to only one conclusion: the engineering labour market for engineering here in Ontario and in Canada in general is saturated, has been saturated for some time, and the saturation has been growing steadily for twenty years. It shows no signs of getting substantially better in the next decade, either.
All this information (the graph previously posted, plus the chart and table posted here) may be found in this report, which I've already linked to- by posting the graphs and charts here, I'm trying to reach the people who haven't bothered to read the report yet:
The report lists all its references and data sources.
Strange how some high schools have higher levels of teen suicides than others, and there are few reported school problems.
The US News high school report, which we started following in about 2005 timeframe continues listing a huge number of high schools across the US that produce graduating classes with an AVERAGE of 9 AP tests taken. My old high school was among them, so they amped up their game as well. The bottom line is that the good high schools have gotten better, with better college prep than ever before. Rising tide arguments aside, it's possible that the worst high schools have gotten worse, but I have no information about that.
I can say that EVERY UC and Cal State campus is inundated with applicants, and even UC Merced has no problem finding qualified applicants. Note that UC campuses require the infamous a-g high school curriculum, in addition to high GPAs and SAT test scores. UC San Diego, which is nationally ranked, reportedly had over 90,000 applicants for fall of 2017 and had no issue waitlisting people with 3.6 GPA and 34 on the ACT. What used to be "safety" schools are rejecting qualified applicants.
Ever since my daughter took the PSAT test last year, she has had hundreds of pieces of mail from differing universities around the country. And several of which I have never heard of.
More recently my daughter had commented that she did not see any calculus on the SAT test she took.
But when you understand that being a social worker also requires a degree, and it does not pay much, one needs to wonder if some university degrees are worth it.
Economics for sure is not on the high school requirement list. So maybe people realize they can make more money with an engineering degree by doing something else.
I hear truck driving pays well, and without the boss always there.
True, but you can take AP Econ, where offered, which didn't even exist when I went to high school.
But the economics is actually a multiple whammy, given that while there is the requirement for a degree, there's nothing that say that degree has to come from USC or somesuch, but the main issue is that there is such a glut of Psych majors that there's no need to pay them larger salaries.
Growing up in NY then living/working elsewhere I have seen firsthand the effects of supply and demand. NY has the proverbial "perfect storm" IMHO, with few exceptions most anywhere you go within the state is <1 hour's drive to a college that offers engineering. The vast majority of them being through the state SUNY system are a great deal for students, live at home or with family cheap and to this day its pretty common for a bachelor's to cost <$30k after all expenses are considered. OTOH, bc of the glut of engineers graduating and industry being taxed out of the state salaries are laughably low. One recent grad I know couldn't "leave home," a BSME only earned him $50k/year, I started $25k higher a decade ago in a dirt cheap section of the Midwest.
One point I feel is rarely mentioned/discussed regarding college degrees and licensure is the difficulty level, or IMHO the lack thereof as compared to the reality of design and development. I have mentored quite a few junior engineers and interns who gave up engineering rather quickly bc they did not enjoy the constant challenges, constant learning, or creativity necessary. Like many colleagues who stuck with the profession only to become lousy engineers, they didn't recognize the difference between being a good student and being a good engineer and weren't willing to put in the time and effort to become the later. To a large extent I believe even folks in engineering tend to overplay the accomplishment of earning a degree or license, nevermind the parents, educators, and other non-engineers. Kids tend to be very trusting so its natural that a certain number go into other professions after graduation.
For instance suppose we want to design a light subframe that will survive driving through a square edged pothole, yet will fail neatly in a front end crash. The crash guys have a couple of dozen supercomputers and years of experience, they don't need to make reasonable estimates, they can calculate what is going on. The pothole people have a couple of strain gauges on the suspension arms and a force measured somewhere, probably not where it is needed, from one test.
Cheers
Greg Locock
The substation across the street does not look like it was off the shelf. And in fact none of our substations look like they were off the shelf.
Maybe parts of it were off the shelf, but it was built by in house crews.
Depends on the definition of "hard" and "pretty." One reason that I enjoy this profession is the variety of both work and people. I've known "engineers" whose day jobs make their undergrad degree seem extremely difficult and others who continually fight a steep learning curve with new technology. Along a similar vein, I know junior engineers earning $50k and several engineers-turned-execs that earn $1M+ annually.
That smells like lower wages or emigration.
And I know a lot of other engineers in my same predicament. One of my problems: I'm "too old."
"No one is completely useless. He can always serve as a bad example." --My Dad ca. 1975
I like it, will probably remember it. Thanks. In my case the few opportunities that come across my desk require relocation or being away from home for periods of time. Definitely, good opportunities are far from abound.
At the risk of taking this thread off topic, I have to say
LOL WHAT?
I am no fan of the previous administration policies, OVER ALL, but I can certainly read. Worst economy in history? For WHOM?
Rate of growth of USA GDP:
http://data.worldbank.org/indicator/NY.GDP.MKTP.CD...
https://www.bea.gov/newsreleases/glance.htm
https://data.oecd.org/gdp/gross-domestic-product-g...
and a more boiled-down explanatory approach here: https://www.bloomberg.com/view/articles/2017-01-19... who places Obama second to Clinton in "best to worst economic performance/strength" during presidential administrations since 1977.
For all the fault you can throw out a sarcastic "THANKS, OBAMA!" the economy is one that shouldn't be sarcastic. If you're to lay economic performance on the President, that is.
" death of one person is a tragedy, if many is only statistics "
There are at least a couple of threads floating around ET from people precisely in the situation. However, there are so many factors both personal and corporate that ultimately determine whether interviews and/or offers come. "I went to a middling university and got middling grades, and now I can't get any responses to my resume," is not an unfamiliar refrain. Supply and demand theory says that only when there's a surfeit of demand will it be likely that all graduates will get hired for jobs they want. The majority of the time, employers are able to pick and choose, and they will often not choose anyone but the very best they can afford.
This is not that different that at the start of the college journey, when you get rejected by even your safety schools, and you start looking at whether CC is really where you'll end up for a couple of years and then hope to transfer to a 4-yr college. Or, do you start looking at the colleges that are still taking applicants, even after March 31. I recall a case where a girl failed to get into Stanford, and decided to go there anyway, attend classes, and con people into letting her sleep on their couches because of "housing glitches." She was eventually found out, but I never found out whether Stanford was her reach school or not.
I graduated into an awful job market, coming at the end of a recession and following the break-up of Britain's nationalised utilities. The market had a lot of experienced labour looking for work, and the area of the country where I lived was hit hard by major employers closing in mining, ship-building and hevay manufacturing. I took a job with a start-up company making about the same per hour as I had in the bar job I had through university. That job was a great place to learn how a company works and be involved in pretty much all parts of the business except the accounts, but the wages were dire. Took three job moves, a couple of relocations, three good relationships wrecked and two years living out of a suitcase to break into the industry I wanted to be in.
I guess the message is that if you want to succeed then you can, but you'll pick up a few knocks along the way. In hindsight was it worth it? Most days, I think I'd say yes.
Something has to be said though about lazy people who are smart enough to avoid anything that is too much work. If you are starting a business, your goal should be to pick a specialty that allows you to be as lazy as possible.
Supply and demand, again. I doubt there are that many specialties that allow you to be that lazy, as it's unlikely that you're the only person in the entire world that has stumbled upon such a gold mine.
Some people are simply not able to deal with failures; they wind up in the herd. Others might be too lazy to look for those mythical lazy opportunities. In between are the those that generate the 90% failures in the 1st two years and the 10% that get to fight on, and fraction thereof that succeed for any length of time.
Longevity is not necessarily a bulwark against eventual failure, Montgomery Ward was in business over 100 years and even though they attempted to survive as a purely on-line merchant, they still could not overcome their issues. Sears, which is likewise 100+ years in operation is teetering on the brink, although it's managed to last slightly longer than Montgomery Ward. Even Macy's is struggling.
That was back in 1991, when about 70% of engineering grads in Canada worked as engineers.
As of 2011, only about 30% of engineering grads work as engineers.
I'd estimate that in Canada, roughly 1/2 the overall graduating class is falling into that disappointment category. They just had to find a job, so they did and moved on. Regrettably though, after two or more years out of the profession, your chances of getting back into it are near zero. Engineering education has a short shelf life.
The universities don't even bother to collect the stats on how many of their grads are appropriately employed- they don't care. The ask grads if they're employed, 6 months and 2 yrs after graduation, but don't ask if they're working in the field they were trained for. Instead they ask them a much vaguer question: whether or not their education was "relevant" to their job. Engineering grads are about as likely as the average of all university grads to be employed 6 months or 2 yrs after graduation. Of course that average includes such job magnet programs as fine arts, journalism etc.
Sadly we live in a society driven by statistics of low value, so long as the headline looks good the general public is pleased. If you want a real chuckle investigate how universities are "ranked" by the media, things like the pass rate and reputation among college professors all seem like grand ideas but IMHO are rather irrelevant vs bottom line returns like percentage of grads employed in their field within X months of graduation and starting salaries. Having attended the tiny inexpensive local campus of a large state chain system for my undergrad I am rather amazed by the number of folks anymore who correlate attendance cost and university prestige amongst the media to education quality. Sadly I've known quite a few with a MS from a major university who wouldn't have lasted freshman year at "lesser" schools, some schools pass the chaff along with the wheat, others cull it.
After all the students expect something for the money someone pays.
Make what you want of that comment.
I don't know if you end up even with a better engineering workforce if all universities culled a good chunk of their class. There is a huge disconnect between academia and industry. I don't know if a prof. is the best person to weed out all the people who would be better off in something else. I probably would have been culled in my undergrad if the classes in my undergrad that I didn't have any interest in were used to weed out bad engineers Would I have been better for it? I don't know but I doubt it.
I do think older engineers have better horse sense. Computers have made people stupid to the point that a lot couldn't tell you what will sort of happen without running a simulation. Be able to run a software package has some how been given the same importance or value as general understanding. I don't know why this is. Maybe, universities should be hammering the basic concepts harder and not go into as much depth. All the deep stuff is forgotten quickly if the foundations aren't understood completely.
I don't think that's a good answer. Some of the best students suck at doing actual, real-world, problems. Other of the best students are simply driven by tiger-moms and will suck at engineering, because they have zero passion for it. Early in college is possibly a very poor point in time to determine someone's lifelong fate. My best friend in college didn't decide on his final major until he became a super-senior. Even given all of that, people change and adapt. I don't do anything related to what I majored in, but I'm still happy and I'm very good at what I do now. And, I might actually be sucky at what I majored in.
And, I don't see that having more people trained in STEM is necessarily a bad thing. Ignorance of science and engineering can lead to bad or ignorant decisions and decision-making.
JME but schools that cull more students typically graduate better engineers and personally I would sacrifice quantity long before quality. I agree that there is a serious disconnect between academia and engineering but I believe the main reason for this disconnect is the seemingly common notion today that every student who attends deserves a degree. The "great" engineering school my wife attended is an example of this, their relatively high graduation rate and low hiring rates are a function of students having relatively little personal responsibility and being held to relatively low standards. They show up for class, are spoon-fed every detail of testable material, and heaven help the professor whose test questions are more than a renumeration of the few basic textbook assignments theyve had for homework. Forcing the students to think and grow by giving trick or challenging questions is frowned upon and there is little time for discussing the realities of engineering or expounding upon the basic material bc students arent forced to read and learn it outside class as they are elsewhere by the threat of failing. Projects are almost always completed in large groups, common engineering classes often sacrificed for easy "fluff" like six-sigma or OSHA certs, and should the student be dissatisfied with their grade then extra credit and curves are readily available. The university brags about higher GPAs and graduation rates but the reality is their grads trade off education and ability. I have sat through many interviews where students couldnt begin to apply basic principles or couldnt recite them, had only rudimentary knowledge of one solid modeler and common software tools, and little ability otherwise but their resume showed 3.5+ GPAs. Scarily enough, many expect roles in project management or other non-engineering departments but at engineering rates. Its reminiscent of the old joke, "Yesterday I couldnt spell engineer, today I is one."
Some of the best engineers I've worked with were rather unimpressive as students, specifically because schoolwork wasn't real-world problems, and they found them boring compared to real-world problems.
While it is not just for engineers, I'd assume the age distribution wouldn't be too far off. There is a trough in the 37-47 age bracket where the supply of engineers is just low.
My anecdotal experience reflects this - like Scotty, I am part of the 37-47 age bracket and had a hard time finding work when I graduated. Luckily, I got a job in the power industry and after gaining some experience, have found no trouble finding work. And it's not because I'm any good either, it just turns out that there isn't that much competition in this age / experience group. For example, at the previous utility I worked at, I was one of only two people in the whole network planning team (of 30+ staff) that was around the same age. Everyone else was either a decade older or younger than us.
10 years younger = cheaper hires
10 years older = managing dept, living with budget constraints, not hiring enough expensive middle managers.
Technology is stealing American jobs. Stop H1-Bs for robots.
Hopefully the firms that became addicted to out-sourcing their entire training cost on others will be wiped out by the coming demographic shift. Perhaps that will finally generate some opportunities for engineers to see rising wages and enhanced working conditions.
Sad to say I have had the same job and pay, but one week the paycheck had one company name, and two weeks later my paycheck had a different company name.
Sad to say some of the new people in the industry work for the new energy sources, but don't have many skills that translate to the utility world.
Outsourcing would be nice if the outsourcing only included the new documentation requirements of the federal regulations. But sadly, the only ones who understand them are in-house, and already have full jobs.
Don't forget, there are a lot of us mechanicals working at utilities too. I have worked for two of the largest power generation utilities in the US (currently at a non-profit co-op district energy plant). I am just on the downward part of the first hump on that chart. It has been quite lucrative for me.
That was certainly the case in the UK a few years ago when many polytechnics and universities got rid of their space-hungry, lightly-used power laboratories full of equipment from the 1950's and 1960's and replaced them with other things which squeezed more people into the available space. More bodies meant more money, and it didn't matter because only a half-dozen kids wanted to study an old-fashioned, maths-heavy subject with zero employment prospects. Awkward bastards like me for example - always the black sheep of any group I'm a member of.
Today the handful of places here that still have a power engineering program - Bath, Newcastle, Southampton to name a few - are very popular, with graduates being sought-after by the generating and T&D companies and earning good money from the outset. It is a far cry from this industry's darkest days in the late 1980's and early 1990's.
Good luck to today's students - power is still (almost) as a tough an option to study as it was back then, and the ones who choose to do so will have to work hard to graduate.
Cheers
Greg Locock
Given the choice of paying a relatively small salary premium to grab one of the grads with a power degree or trying to train an electronics grad who never had the chance to study anything in our field, most employers would pay the premium for the power grad because, with all other things equal, the new employee becomes a net contributor more quickly.
My alma mater now offers environmental (civil stream- they fortunately canned the chemical stream), mechatronics, nanotechnology engineering, management engineering (barf!) and biomedical engineering in addition to the usual civil, chemical, mechanical, electrical, computer, systems design (i.e. industrial) and geological. The previous nuclear specialization died in the '80s.
Industry by and large doesn't know what the hell to do with these people. What the unis are doing is hiving off core courses from the underlying discipline and replacing them with courses related to the specialist subject matter. It's not just a matter of taking credit for a few technical electives in 4th year- a chemical stream environmental sacrificed heat transfer as one example. That's a core chem eng course. If they hacked away a couple of the useless higher math courses, pointlessly teaching analytical integration, that would be a different matter!
Nobody is getting a nanotechnology specialist job with a B.A.Sc. in nanotechnology. No, you're going to need post-grad to do that- so why RUIN the undergrad degree by chopping core courses?
I suppose management engineering (barfs again) seals the transition of engineering from basic training for a profession to "the new liberal arts education", or a sexier business degree.
I agree that engineering employers have to produce their own professionals from good raw materials. The university's job is education, not job training per se. And when they try too hard at the job training bit, they fail, badly. What works better? CO-OP work as a mandatory part of the educational process. That actually generates engineering grads who really are able to hit the ground running.
Unclear that this is true, given: http://www.nnin.org/news-events/spotlights/nanotec...
Why chop core engineering classes? To make the overall program easier thereby improving GPAs and graduation rate, thereby improving the school's ranking in irrelevant media reports. "Nanotechnology" also makes for better advertising than "mechanical engineering" to the ignorant.
The discussion above about power engineering is an example of the specialization that has already occurred in the electrical engineering arena. 70 years ago, there wasn't much to distinguish power EEs for other EEs since they all wound up taking the same basic courses. Today, an integrated circuit design EE would probably have very little overlap with a power EE. I had many courses on transistor (bipolar and MOS) circuit design and modeling, while 70 years ago, the bipolar junction transistor had barely been invented and the MOS transistor wasn't to make its debut until about 55 years ago, and a whole new field of physics and engineering had to developed to support the industrial needs of those devices.
But just a question about why we are not hearing about robotics engineers, or shortages in that field? And maybe because robotics is covered by another type of engineering.
I can tell you that my alma mater struggles to find co-op jobs for their nanite undergrads, and we see many former nanites transferring back into chemical after a few terms after waking up and smelling the cat food.
Our efforts in quantum dots were all purely engineering aspects of how to disperse them covertly and track them, well within our lowly Bachelor's degree purview.
Nevertheless the note had a positive spin:
"It’s pretty obvious, your time is now! Positions are hard to fill, salaries are on the increase and you want to make sure that you do not miss the opportunity to position yourself in the right role, with the right salary and the right future career prospects so you can also benefit and prosper over this next boom period. How you do this, is where it gets a little complex - if you are in a role now where you really feel that the role equals the rewards, good for you, however if you have been in a role for a while with no salary or career review, you should be questioning your employers commitment to you. "
We are all very well aware that the Australian Construction Industry is on the precipice of an unprecedented period of significant growth in NSW/Victoria and SA in delivering Road/Tunnel/Rail Transport infrastructure Projects over the next decade. It is exciting that we are in one of the key industry sectors along with the Health (health and aging population), Wealth (Management), Logistics, Tourism and Education that is going to drive the economy for the next 10 years or so.
When it comes to staff recruitment and retention, this Transport Infrastructure boom is going to bring some significant challenges to Engineering and Construction Groups of all sizes, as experienced previously in the mining and oil and gas boom. .....already seeing talent shortages growing already in many areas such as PM (especially RMS experienced), SPE-PE and Supervisors (where have they all gone?). I have recruited specifically in this sector for 30 years and I predict that the next 1-3 years will be the most challenging period ever when it comes to Civil Construction recruitment as there seems to be too much work to do with too few resources to deliver. It is also important to remember that Australia is not the only Country with this issue, as Globally the Construction sector is predicted to grow by 85% to $15.5 trillion by 2030 so the usual recruitment drives to the UK, RSA and UAE will not deliver the same successful outcomes as was achieved previously.
So what does this mean for you as an extremely valuable, scarce and local individual with a strong career to date and demonstrated experience delivering Transport Infrastructure Projects?
This is a hard and challenging industry with long hours, high pressures and expectations and all under tough and demanding circumstances so it is important that you feel comfortable that you are being acknowledged and looked after by your employer, and if you aren’t - there are plenty of opportunities out there for you!
RE: A coming engineering shortage ? ---- Who agrees ?
Have you been to the US? We have TONS of foreign engineers (among other STEM and health related professions). When I was in college, at least 50% of my class was foreign students. Most of them stay here after graduating. One of my current colleagues used to work at one of the largest oil and gas companies in the US. When he was there, there was a group of engineers known as the Venezuelan mafia. The company would advertise engineering positions with low salaries to avoid local candidates. Then they would claim that they couldn't find suitable candidates and use visa programs to bring in guys from Venezuela at 50% or less or normal US salary ($30-40K a year).
Not sure where that comes from. Companies all over have been clamoring for more H1Bs because of the supposed shortage of engineers. Not only are they getting the cream of the crop of foreign engineers, the H1B sponsorship pretty much locks them into a single job with little chance to job-hop to jack up their salaries.
But, it's not just engineering jobs that are like that. You don't see many white people working in the farms in the California central valley, do you? The same sorts of arguments show up there as well.
TTFN (ta ta for now)
With this and other caveats; in 2013 All Scientist and Engineers (S&E)...
S&E Occupations: 5,749,000 (24.4%)
S&E Related Occupations: 7,439,000 (31.6%)
Non-S&E Related Occupations: 10,368,000 (44%)
https://en.wikipedia.org/wiki/H-1B_visa
The data shows a 223,000 increase in H1Bs since the recession.
You clearly didn't work at my (recently) former employer in the nanotechnology field.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
It's such a mixed message from company to company. I've worked at places where being good at CAD is almost mandatory for the engineers who work there......the next place, they will have a stroke if you even think about doing it. (Reserving it for drafters because of lower rates/hour.)
Ever-the-more, I believe H1B visa is lumped under the "Temporary visa holder" or "Immigrant" column. The original numbers I posted here appears to point to over 50% are in the technical related field. Perhaps a bit better than Ontario?
In terms of supply-and-demand, prices have been going up in this ASME/ASCE survey: https://www.asme.org/getmedia/788e990f-99f5-4062-801c-d2ef0586b52d/32673_Engineering_Income_Salary_Survey.aspx
Exhibit 1 has a median salary increase of 4.7% into 2012. Sample size is ~11k
Exhibit 3 has matched sample median increase of 4.4%. into 2012. Sample size is a smaller (3551).
When compared to the ~1k organizations surveyed by Aon in 2013, the overall salary increase budget went up by 2.8% in 2012 (page3-NotTheSun).
http://www.aon.com/attachments/human-capital-consulting/2012-2013_US_Salary_Increase_Survey_Highlights.pdf
I'm no economist/sociologist, this suggest to me there is currently no shortage in engineers.
The most interesting finding was a comparison of the salaries of engineering grads working in engineering (about 30% of the total) versus those who worked outside the engineering profession (about 70% of the total). The median salary of the engineers was 20% higher than that of those eng grads not working as engineers. So if, on average, those people left the profession by choice, they did so against their economic interest.
The survey of 4th year students demonstrates that amongst Ontario engineering grads at least, the vast majority of those who do not gain entry to the profession after graduation do not do so out of choice, but rather by default because of a lack of opportunity.
Politicians, universities, immigration, globalization etc disrupted the social balance on grand scale. Lets call it social engineering for what it is. It is all about control of resources and markets.
As an overall profession there may well be a surplus over demand, but it is simply wrong to assume that the surplus applies uniformly throughout every discipline and every specialism.
There is no shortage of engineers;Semicolon
Neither is there a shortage of cars on the road. Prices of both cars and engineers have been steadily increasing despite increases in both population because the demand is strong. Things sure look different in Ontario where engineering wages appear stagnant. I agree with moltenmetal, there is glut there. The rising engineer's wage in the USA indicates there isn't a glut or shortage here. On average, our engineering labor market is humming along healthily.
You have a long list of conspirators for social engineering. Count me as one of them. I'm proud to be an engineer and would not discourage talented people from joining our ranks. Cooperation and healthy competition makes life more interesting than a quasi-monopoly.
True, there are engineers who struggle to find a job for various reasons while others command astronomical salaries. Statistics provides only broad strokes. It is still superior to anecdotal evidence and more importantly keeps us from straying too far from reality with our personal bias.
That's the challenge, though, isn't it? We certainly don't want to discourage talent, but we do want to discourage the untalented and incompetent.
Was that before the E3 visa? In 2005 I think it was when we did a free trade deal with the US, George Bush threw in a sweetener in the form of the E3 visa specifically for Australians. Apparently it was for being a part of the "Coalition of the willing" and sending troops to Afghanistan and Iraq.
So long as you've got a degree they pretty much let you straight in. Fear not though Americans, we are JUST as greedy as you all are when it comes to salary
And maybe that's the issue, some of us don't like living in some of the hell holes that exist, no matter what they pay.
What are you talking about rising engineering wage?
The flat portion of this graph is rising slower than inflation.
https://www.naceweb.org/job-market/compensation/sa...
Thanks for sharing the link! I'm unable to replicate your plot from the website data. Can you elaborate on the source of the data for your plot? Figure 4 of the website shows adjusted increases that doesn't match.
Quoting from last sentence in first paragraph: "Overall, in real terms, bachelor’s degree level salaries have risen 5.9 percent since 1960."
Under the appendix section Figure 11 for Electrical Engineers, There are 4 columns of data: Year, Reported Average Starting Salary, Percent Change, Adjusted Average Starting Salary, Percent Change. For convenience, I've plotted just the salaries below.
If we consider just the recent (unadjusted) data, starting Electrical Engineer salary in 2005 was $51,773 while in 2015 it was $67,593. That looks like rising wage to me.
http://imgur.com/gf1J2Xx
http://imgur.com/y9D9C82
From $51,773 to $67,593 over a ten year spend comes to 2.6% annually. Basically, inflation. Maybe, less depending on how you calculate inflation. There is nothing rising about that.
Yup! It's rising with inflation more or less.
Returning to the side question: is there a shortage/glut of cars? The price would fluctuate with the economy (like salaries). I would say close to matching inflation means there is no shortage or glut of car (see below) or engineers. The engineering labor market is doing OK.
Over the history of the automobile, inflation-adjusted price to 2013
https://simanaitissays.com/2013/04/22/new-car-math/
The corrected data says there's a 0.8% per year rise above the inflation rate; it beats being flat AFTER inflation.
I remember there was a statement made by Allan Greenspan about 10 years ago about income inequality. His solution was absurd, but not unsurprising from the captain of parasitic free market capitalism
http://archive.boston.com/news/nation/washington/a...
That was pretty much the call to corporate America to turn their lobbying efforts towards immigration and open borders. Of course there was no mention of the biggest causes of inequality, like a tax code that favours capital over labour, excessive executive remuneration, wall street bankers, or you know, trying to help those at the bottom get better wages.
It's like when I use the align command in Mathcad. The tops of objects that are high move down, and the tops of the objects that are low move up.
The issue is that those curves show that other professions and jobs are either completely stagnant or actually decreasing in real dollars. Adding more STEM workers will do the same to engineering. But, as usual, there are still those that stubbornly believe in supply-side economics, even though it's been disproven, over and over.
Actually, in my mind, bringing in engineers from other parts of the world will increase the demand from other countries, and should increase wages. What actually happens is that schools try to push through more engineers, by lowering the quality of the education. So we see more non-functional engineers, and wages go down.
Quantity over quality. That is what is happening. Garbage engineers who can't do the work.
We also see that in government regulations to mandate a structured flow process so as to reduce the need for thinking engineers. I.E. we are being replaced by computers and administrators.
Conversely, though, a lot of my classmates end up NOT being engineers, i.e. they got sucked into high-tech jobs, as engineers have a lot of transferable skills to other industries (management, tech, marketing..etc.).
What I can also add, anecdotally is that a lot of EE roles are being developed overseas. So there is a lot lower demand here in NA for hardware EE, as work are being outsourced overseas.
Not a lot of answers, just more observations.
As for continual training and career growth opportunities, if you aren't getting them and have no financial obligation to stay (pension, ownership, etc) then move on, there's far too many good employers to stand by those that are dying. JME but if someone hopes to get into advanced technology development they need to find a company with a strong forward-thinking training and development program, with the proprietary nature of analysis you simply wont get decent FEA or CFD training elsewhere.
But some industries do build projects, rather than manufacture products. So that might be the difference.
Also as an older engineer, it is part of my job to provide training to younger engineers, except I am not allowed to flunk any of them, and there is no diploma.
When you hire an engineer, how do you know the quality without the paperwork? How do you know they have had additional training, and if they passed?
Even work that has to be stamped is being outsourced/offshored. It gets designed overseas and a guy registered in the States reviews (hopefully) and stamps it here.
Peace on Reagan perhaps.
A few years ago a handful of people over here were mourning Thatcher's death. I was too busy mourning her birth, along with most people in my patch of the country. We are still harvesting the poisoned crop she sowed.
http://www.theage.com.au/national/education/career...
Cheers
Greg Locock
Where I live, the Registered Nursing profession has seen a starting wage increase in 30% over the past 10 years, and now I see billboards for the local health systems offering anywhere from $7,500-$20,000 starting bonuses-and they put this up on billboards! The local hospital (owner has hospitals in three other metro areas in the region as well) has 838 listings for nursing openings. Our state alone has 434 across multiple employers (hospitals, clinics, nursing homes, home healthcare, etc).
Engineering starting salaries in our region have seen a 10-15% increase in ten years, and nobody is offering starting bonuses of any magnitude (maybe a couple thousand bucks to offset a moving trailer), and you certainly don't see bulletin boards about it!
I'll believe there is an engineering shortage when I see the market response the nurses are seeing.
That's not necessarily the only reason for not changing jobs:
> commute -- yes, I could change jobs if I were willing to put up with a 1hr+ one-way commute, but that's nowhere within my cost/benefit analysis space. I could move, but I like my house more than I like any company that's not within a reasonable commute
> starting over -- a new job entails a significant time to build up one's creds and reputation; often, one enters a new job essentially as a noob in the pecking order. Finding your new spot takes time and energy, neither of which I want to expend at this point in my career
> crappy people, etc. -- when you find a job where the crackheads and difficult people are gone, for whatever reason, that's hard to give up. Going to a new job entails the possibility of running into, and afoul of, self-centered nitwits, idiots, and other forms of lower life. These are chi-vampires; they suck your energy and give you nothing in return. You can't be sure of running across them during a single day interview, so it's a gamble. Often, you don't even find them until re-orgs and whatnot shake them loose from the woodwork, and you find yourself writing Pearl Harbor memos and pondering when to give them the finger and walk out.
I've changed jobs 7 times, more or less, not always voluntarily, and there have been at least few times in previous jobs where the above bullet points were true. There's one guy in the current company that's a bit of a chi-vampire, but only because he whines about having never done something before, which is a real motivation sink during a proposal. But, he's not always on my proposals, so I can live with that.
IRstuff - I like your comments about " crappy people" oh boy .... when you come across toxic people my best advice is ...run. Life is to short to put up with that.
Of course there are other factors to be considered when contemplating a job change and each one should carry some weight. I always factor those in as well. I have excel spreadsheets that I made for economical analysis that include commuting costs, time spent on work related activities (commute + expected hours at work), benefits costs, state and local taxes, etc. Luckily, I don't mind the starting over part since I tend to make an impact and get noticed for my abilities rather quickly. Could that not be the case somewhere, sure, but so far, it has always worked out that way for me. As for people, I just see people as people. I don't expect to go anywhere to make new friends. I just keep it work related and build good working relationships. This has also proved very successful for me.
All that said, I have turned down significantly more jobs than I have accepted due to commute considerations and/or vibe I got during interviews. The current place I work now had some questionable individuals that I met during the interviews and it increased commute from 7 miles to 33. I was on the fence on this one, but I saw the potential and it has been a great job change.
Well...
I resemble that remark.
The bottom line is that some people love change, are adrenaline junkies, or they're ambivalent, or they hate change. It takes all kinds of people to make a good team. Having no tribal knowledge can be a really bad thing. There needs to be some old curmudgeonly geezer that can tell you, "oh yeah, we did that 15 years ago, and here's why that was a disaster." That actually happened, but the old geezer was only IBM Tech Systems Journal that had a paper from 15 years prior explaining why we were $3M in the hole because some lame maintenance guy decided to monkey with the previously qualified and working process.
Engineers, as a group, tend to be negative and I've heard that comment from quite a few non-engineers. Life is never so bleak as some think, including me. And life is very hard for me right now so I am no Pollyanna.
Whether there is a shortage or not, nature and nurture will still effect engineering. People usually move towards their desires even when outside motive forces are not acting upon them. In short, I don't know that we have that much control over numbers in the profession. We do not need to sell young people on STEM. We need to educate them about it enabling them to make a good decision for their lives. It's not about us but them and their interests. We've made our decisions.
I've been participating in the Central Chapter of NSPE-CO, since 2014. It's been quite an education. I understand the importance of licensure and membership in NSPE better now and I am still learning. It is interesting to listen to engineers, attorneys, and insurance companies discuss problems that arise and how they are dealt with, in and out of court. One engineer has been in court numerous times on various things and always takes in a wagonload of documentation and ensures he is familiar with his wagonload of documentation. It matters and is not insignificant. There are many such stories engineers tell about this kind of thing. Attorneys and insurance companies have some interesting stories.
With changes coming in technology, I believe licensure will become even more important and widespread. At least one old industrial company has done away with the industrial exemption and spent several hours explaining what that meant to their engineering staff. With autonomous vehicles coming, based upon some of the presentations I've heard on it, the automotive industry will probably change. I don't know how ubiquitous that thinking is as it is just my opinion based upon what I've learned in the last 4 years of membership in NSPE. My former employer didn't want to assume the legal responsibilities for its engineers any longer and I cannot believe others will not follow suit.
Licensure in the USA is rooted in the US Constitution through Amendment 10 as well as Article 4, Section 2. With that in view, I foresee licensure for engineers as transportation technologies advance.
When I researched ABET's and NCEES's websites, I began to realize that licensure is not insignificant because a lot of effort goes into making it possible. It provides a standard to measure competence much like licensure for physicians and attorneys. And for those who don't put much stock in standards, let's go back to no standards on threads, fiber, etc. and see how good everything works. I know there are problems everywhere but it's a place to begin.
Life events are seldom simple and people are seldom simple. The state of industry, engineering, society, etc. are due to a host of factors, to me. In the USA, a general coarsening of our society has occurred over my lifetime, which is disheartening. We don't value human capital. We have isolated ourselves into silos, which is destructive. This statement reflects some of what I see, "I just don’t understand the disrespectful attitude toward working people.” Source: AFL-CIO CEO-Worker Pay Ratio
Pamela K. Quillin, P.E.
Quillin Engineering, LLC
NSPE-CO, Central Chapter
We're the ones who see the practicalities and the difficulties in doing something, and we speak up about those things because we understand them. In the eyes of the dreamers we're negative because we shoot holes in their ideas right at the outset. I actually think we're some of the most positive people out there: the optimists who say "Yeah, it hasn't been done before, but we'll find a way to make it work even though we aren't sure quite how." Our underlying optimism is often masked by other traits though, like the cynicism which often develops after a few years in the business, and our seemingly dogmatic application of 'the rules'.
We don't help our cause much do we?
Cheers
Greg Locock
We do see a lot others don't but, even when they do see things correctly, we often shoot holes in their ideas and them.
Yeah, BTDT; it works great with SWMBO
One thing that I've considered in such things is that the person who is floating an idea has never asked the basis questions.
1) Why has no one else thought of this?
2) What do I know that no one else does?
As long as the answers relate to corporate inertia or being the first to the party then there's a chance to succeed. Apple computer, for example, benefited greatly from IBM's inertia and Google was the first to understand the page-rank concept.
But what kills me is when someone is basically saying they are so smart that they alone, with no research at all, have concluded that some idea is the best idea. And I find the reason they think they are so smart is they have done nothing to build a basis of comparison.
**The management guy who was leading this also led a project that 3 of 3 engineers said was a bad idea and forced me to use a mechanism I was told later had failed in a prototype stage but they didn't pass that information along to me before demanding I design using it. What was interesting is the core component was purchased from a company that had motive to design a system just like the management guy was going for, but he failed to ask either question. As soon as it was all assembled, it immediately failed and they threw 3-4 years worth of my salary in the garbage and pretended it didn't happen.
I could have saved that company a lot of money by just not working on what the dreamers came up with.
My florist bill is rather high
We used to have a guy who was the gatekeeper for IR&D (independent research and development), always has two showstopper questions. When we first went to him for a new project, he'd ask, "Is anyone else doing this?" We answer "no," and he'd say, "then why do we want to be the first?" Next time around, he'd ask his same question, and we'd answer "sure, A and B are both pursuing it." He'd then say, "so why do we want to be doing the same?"
So, those are always good questions, "are we really the only people the universe to have thought of this?" and, "if this is really a good idea, why aren't there more people doing it?"
Tone the sarcasm down a little. Tell us what really happened.
One good example was my last employer outsourcing the design of a new variety of widget rather than hiring internally. The firm hired had no experience in that area and after a few initial concept reviews it became painfully obvious their analysis was flawed. It became a "us vs them" scenario but because management had pitched their involvement as beneficial and contracts signed, internal experts were excluded and their opinions were dismissed, and the powerpoint engineers continued unabated. More than a year later the predicted project failure occurred and the company had no recourse. The failure was swept under the rug as being due to insurmountable issues when in reality it failed due to incompetent engineering. Others may disagree, but I am very careful to take unsupervised design responsibility only on things which I have experience with as I view it unethical to work outside my area of experience. Garbage in and a pretty picture out does not make a successful test, and many things cannot be learned except by experience testing what works and what does not. If I was risking only my own money and time that would be one thing, however doing so for an employer or client is quite another.
Often the attempt is to promote them in a role they cannot make much damage, not always the case.....
But often real learning happens when he has to fix his own mistakes.
Shortages happen when companies are not willing to create training positions. There may not be a shortage of newbees, but there will be a shortage of knowing olders soon enough.
God made the integers, all else is the work of man. - Leopold Kroenecker
I don't think I'm going to run out and snap up the hard-copy, mostly because I don't have access to the waiting rooms or parlours where it would be best skillfully and artistically placed.
(If this shows up as shouting, forgive my less-than mastery of Chrome in the real world)
(Me,,,wrong? ...aw, just fine-tuning my sarcasm!)
Nowadays if a new grad has completed no internships and graduates with less-than-stellar grades, he can be unemployed for a VERY long time after graduation. But the "human resources" people who hire them think not about such human issues as students who have the will but not the way! Financially-independent students who have to work, beg, and borrow their way through school inevitably work full-time in the summers and part-time each semester. In summers they may be forced to work higher-paying jobs than those internships. Of course they have less time to devote to studying as their fully-funded competitors so they get lower grades (and a LOT of stress!). But HR people don't care about such things and routinely pass them by due to their unbreakable hiring requirements.
H. Bruce Jackson
ElectroMechanical Product Development
UMD 1984
UCF 1993
"Nowadays if a new grad has completed no internships and graduates with less-than-stellar grades, he can be unemployed for a VERY long time after graduation. "
This seems to be the non sine qua of today's college student school year, my own kind among them, and has now become a crisis of its own, because so many students now are looking for internships from the start of the school year that they getting harder and harder to find. It's to the point where it's Labor Day, and the kids are getting harassed about not having found an internship for the coming summer, AND, most of the good internships are mostly scooped up by October.
That being said, I'm not so sure a hiring manager should consider that a make or break deal. I haven't noticed much of a difference between ones that have or have not done a internship (except maybe CAD skills). I've seen graduates who have done some really good research....that should be a factor as well.
The constant drumbeat of the STEM crisis has increased the student enrollment in STEM disciplines by 50%, and now, the only way to weed down the applicant pool is to tally the number of internships acquired.
H. Bruce Jackson
UMD 1984
UCF 1993
Because even if they end up as a cab driver, it is still mostly like a much better life than whatever third world country they came from.
Many more never achieve that success, or only achieve it partially or only for a time.
I would say that with the possible exception of refugees and asylum seekers, all of them come in the sincere hope and belief that Canada is a land of limitless opportunity and their success, while not certain, is reasonably probable.
The statistics would tend to give them reasons to shake their heads and re-think things a bit.
The reason the immigrant engineers aren't achieving even the pathetic conversion of engineering education into engineering labour force participation in Canada that the average Canadian graduate achieves isn't as a result of racism or xenophobia in my view. Canada and Canadians, on average, have an overwhelmingly and somewhat uncritically positive view of immigration in normative terms, though racists and xenophobes both general and selective do exist here as they do everywhere in the world. Rather, immigrant engineers fail in huge numbers here because they are often viewed by employers as an unnecessarily high "hire risk"- a risk which it isn't worth taking unless the labour market is actually tight enough that they have no choice. Given that the labour market for engineering here in Canada is by no means tight, nor has it been even close to tight for a very long time. There is a perennial shortage of people with 10 yrs of local experience who were not hired as fresh grads ten years prior in that industry, but that's a role that many immigrants to Canada cannot be reasonably expected to fill right out of the airport arrivals gate.
This seems worth exploring; why do you think there's a perceived risk? If anything, one would think that immigrants would pose a lower job-hopping risk, or is it some other risk?
I am sitting here in an office in Kitchener/Waterloo, and it appears to me that most of the engineers here graduated from the nearby and well regarded University of Waterloo. Obviously, if you were trained in India, Russia or China, you are not a Waterloo graduate, and your resume will move down the stack. Lots of Waterloo graduates are New Canadians. Even if you cannot break into engineering, your kids can.
JHG
Who exactly has no choise, employers or employees?
Would it not be easy to hire someone from the university down the street?
It would be different if you were hiring someone to cut your lawn (Have you ever run over your own foot? Do you know better than to attempt to cut grass after it has rained?).
I Australia they have a working visa 457 that is heavily abused by businesses to bring in cheaper labor....
How do you do a background check on a company ? You remind me about the Canadian mining co called Bre-x....
The reality is the universities are pumping out graduates (business sense) to an ever shrinking engineering market that mostly shifted to low cost countries and emerging economies...
The first graduated from a local university and has ten years working in the local market- five for one of your competitors, another five for one of your suppliers. They have references that you know personally- maybe even people on your own staff, and others you can get on the phone in five minutes. They come in familiar with both your suppliers and some of your customers, have a professional engineering license in your area, and already have a line on a couple potential projects they may be able to bring in with them either now or in the near future.
The other graduated in another country and studied in a language other than your local language- one of ten thousand such programs and universities/colleges in the world, about which you personally know absolutely nothing. They have the same ten years- or even twenty years- worth of experience, but all of it was gained in another part of the world where the codes and standards of practice are similarly either incompletely known or totally unknown to you. They pass a technical test for basic technical skills and seem to know their stuff, but communication is a bit of a struggle . They're eager, and willing to work for $10,000 or even $20,000 less per year than the other person- this year at least. They have no license yet, because they lack the year's worth of local mentored experience necessary to get one.
Which of the two would you consider to be a greater hire risk?
The latter candidate is a reasonable composite of at least 100 foreign trained engineers I've interviewed over the past couple of decades- at least the ones who met the basic technical competency requirements (which some local engineers also fail).
If the former candidate doesn't present themselves for an interview or is somehow imperfect, you may choose the latter. If you have ten of the former stacked up in the resume file because the labour market is saturated, you're not even going to interview people in the latter category.
Is the exclusion of those foreign-trained engineers from consideration "discrimination"? Selecting which candidates to interview and which interviewees to hire is FUNDAMENTALLY a process of discrimination. The key is to ensure that the discrimination isn't happening on the basis of grounds not materially affecting job performance. Race, country of origin, sex/orientation etc. are such grounds- but communication skills, work experience in the local milieu, access to local references etc.- those are NOT arbitrary grounds, they're meaningful selection criteria because they can be demonstrated to have a meaningful effect on actual job performance, especially initial job performance. Generally, you're hiring experienced people to fill an immediate need- team-building over the longer term can be done with more junior staff who obviously are going to be selected from the local pool of graduates.
We've had good luck with some foreign-trained engineers- some of them really exceptional- but we've also had some spectacularly bad hires who cost us a lot of money to regret. By far, our best luck has been with co-op students who we've mentored and trained ourselves. They represent near zero hire risk- we can say that now that many of them are still on our staff after over 10 yrs on the job.
What saddens me even more is that many immigrants, refugees and asylum seekers come to Canada knowingly sacrificing their career aspirations for the benefit of their kids' futures- and then put their kids into engineering schools, whereupon the grads are dumped onto an oversupplied local labour market and forgotten about- expected to sink or swim on their own merits, despite the oversupply. It's ridiculous.
The only reason US wages have finally started upward the past year is because the unemployment rate is now so low and Trump and his minions have snarled immigration. That helps us, but I don't think that's what his big money donors wanted.
Wage increases have been possible during the previous administration's reign. I increased my wages 110% from 2010 to 2017.
Yes I get it that universities don't teach much in the power area. I also have to say those grads who think it is easy, and you just follow the book, are wrong, and find mid life that they have worn out their welcome at so many places (job hoppers we call them).
And that is a limit in this industry, you can't assume the books are 100% right. You have to think out side the box, and many grads have not learned that, and can't do that.
Maybe that's the need for excess engineers. People who can do it, and people who washout. Maybe the universities need to make the education harder so some people wash out sooner.
Every chance they get, employers will scream "shortage!" at the top of their lungs.
Ironically, their short-term thinking actually generates real shortages- of the people with ten years of experience that their field didn't hire as fresh grads ten years prior. Equally regrettably, those positions aren't easily filled by immigrants either- they don't fit the bill completely for the reasons mentioned in my previous post.
Engineers imported from overseas as Australians struggle to find jobs
Anna Patty
When Kenan Toker enrolled to study electrical engineering specialising in power generation, he thought he would be training for a job in a growth industry full of opportunities.
But after graduating with his engineering degree earlier this year, Mr Toker, 24, from the Sydney suburb of Mosman, struggled to find a job
Workplaces in general can become "closed shops" because hiring competent people from a pool of applicants is difficult, time-consuming work to do well, and does bring a high risk of failure. That's why people are so big on "networking", because most positions are filled through contacts within the networks of the current employees. That's a hard thing to break into as either a fresh grad or a fresh immigrant, and next to impossible to break into in a saturated labour market.
I've worked at several places where that was just a total, unmitigated disaster. Buddies getting buddies hired and then they'd get fobbed off on the unsuspecting people who didn't know them. One boss I had fixed that one fast: he set it up where if you got 'em hired......you are the one who will work with them. That cut down on some of it.
- The government advertises to the world saying 'Hey everyone, we have an engineering shortage! You'll definitely get a great high paying job if you come here. Just give us the $5000 visa application fee, non-refundable of course, and we'll make sure you have a great opportunity waiting for you when you arrive.'
- The engineering bodies advertise to the world saying 'Come to Australia. We have an engineering shortage and it'll be incredibly easy to find a great high paying job here. Just give us $1000 to transfer you accreditation otherwise you'll be placed at the back of the list. Still can't find a job? Well dummy, that's because you're not chartered! Just give us the $1600 chartered application fee and you'll have a job in no time!'
- The universities advertise to the world saying 'Have you heard Australia has an engineering shortage? Well unless you're educated in Australia you'll be looked upon unfavourably when applying for jobs. But don't worry! Just give us $3000 per unit per semester for 5 years and we'll make sure you come out with a great qualification that will put you top of the list when applying for jobs. Did we mention there's an engineering shortage?'
Migration is big money for government, engineering bodies, and universities. They're not going to let saturation of the market stop them from making a nice bonus.
Later our at the time brand-new engineering advocacy body in Ontario (OSPE) got in the mix. It was offering training courses to engineers and soon realized that it was worth trying its hand at providing a "job skills" program to foreign-trained engineers attempting to find work in Canada. This was during the 1999-2003 peak of "skilled worker" immigration, when as many immigrant engineers were trying to settle in Toronto alone as we were graduating from all our CEAB-accredited university programs in the entire country combined. It was when that program, which was costly to both the provincial government body that funded it as well as to the participants in the program, failed to find positions for about half of its pilot participants during what was constantly hyped in the media as a period of "generalized shortage of skilled workers", that OSPE started wondering what was really going on in the engineering labour market.
Regrettably it took twelve years- between 2003 when the problems with the OSPE program came to light, until 2015, before OSPE could manage to get its head around the fact that not only was there no engineering labour market shortage, but rather the exact opposite- a massive, persistent and growing market over-supply. That's when OSPE finally issued the report I've linked to repeatedly here. Of course because senior people in the profession to this day still either refuse to believe the data, or perhaps more cynically because some of them profit personally from the ongoing oversupply, the report was not promoted actively by OSPE and has therefore had virtually no useful effect. It has had no meaningful impact on Canadian immigration or Ontario educational policy that I can detect. But it does serve as a useful source of data to counter these claims of "shortage!" when they (continue) to rear their ugly heads.
My experience has also been that nepotism in hiring rarely leads to anything but incompetence. I'm not sure which is worse, giving friends/family hiring preference or graduates of a particular school. The first isnt too popular IME as many companies have policies against it. The later OTOH is scarily popular, particularly among managers who are also school sports fans/boosters. Personally I've always recommended hiring the best candidate for the position. With today's recruiters advertising on the internet hiring is a pretty simple process. Either folks can prove their worth in the application/interview process or they cant, the risk is only in hiring those who cant claim any experience.
That's rather broad brush, and ignores the fact that certain schools simply are better, and their students are culled from the cream of the crop to start with. Given a choice, would you hire a doctor that graduated from Harvard vs. one that graduated from Instituto Tecnologico de Santo Domingo?
Would you pick a BSEE from Stanford or one from Texas A&M? In the TV series "Suits," the law firm Pearson Hardman hires only Harvard Law graduates.
Now, from actual experience, I can only anecdotally say that I once interviewed someone from a large school known for sports, and the interviewee, who allegedly had nearly 4.0 GPA, couldn't solve a simple TTL circuit problem, even after been told what the solution was, and then proceeded to not be able to solve the same problem yet again later in the day.
I disagree that the government, per se, has a motive; the upfront fees will never fully cover the unemployment costs later on. Nevertheless, politicians, being in the pockets of big business will spout the business party line, because it's always in the best interest of business to get cheap labor, particularly if the technical risk is sufficiently low. There was a brief period of time when India was successfully marketing to off-shore receptionists, by having a someone in India live on a monitor in the foyer, ready to assist the incoming visitors. While we never partook of that, we also never replaced our receptionist.
H. Bruce Jackson
UMD 1984
UCF 1993
I can only share my experience, which has been that managers who discriminate against candidates that didnt attend their own alma mater tend to also be bigger sports boosters.
As for "better" schools, while I've known a few top engineers from "top" schools, most that I've known from those schools have been rather average and some disappointingly below average in success after college. In decades past stereotypes about graduates may have been more true but IME today its a fool's errand to make such assumptions. Personally, success after graduation speaks louder than school lore to me. While its nice to hire the most highly educated folks available from what others perceive as "top" schools, I'd weight patents, papers, and significant projects as much more important on a resume and better indicators of future success.
That's what happens when you use a single value to gauge the economy. Nevertheless, the detailed statistics exist, and are not buried by anyone, government or otherwise, which is why https://spectrum.ieee.org/at-work/education/the-st... has a nice graphic that shows that there are truckloads of STEM graduates who are not working in STEM. None of the conclusions are necessarily new. I graduated in the late 70s, and all those bright shiny math majors found out that there really weren't that many jobs for theoretical math majors, so they did programming, and even some jobs that were at least partly math related, like accounting and actuarial work. Then, there also those that majored in Eng.Lit. and History in a heavy-duty engineering and science school, so they ditched their STEM option even before graduation.
Not knowing the quality of the school at Stanford, I would choose the Texas A&M grad. After all none of those Eastern schools seem to shine very brightly in the Western US.
The quality of the grad's has little to do with the quality of the school in what I have seen. There maybe some edge, but it is not a complete advantage.
The problem as I see it is book smart does not always translate into being able to actually make quality decisions.
Also the company culture has a big influence in the employment outcome.
And the grad from down the street, who has lived in this community all his/her life is more likely to stay here.
Cheers
Greg Locock
H. Bruce Jackson
UMD 1984
UCF 1993
If I were to try to hire on a trait of new hires, it would be the ability to self teach. It doesn't have to be complicated stuff but can you pick up a standard, read it, and actually understand what you read. Or even just dig into a hobby that required them to bootstrap themselves.
http://www.gradeinflation.com/
Good luck finding data.
Cheers
Greg Locock
Someone I know was able to get through the UC Berkeley EECS program in 3 years and with a $100k job offer on the table at the start of their junior year. but, obviously, that's a special case; there are also lots of CS majors still looking for jobs.
Weeding process should start even before uni/college acceptance. The inflation in number of students, a fact loved by gov and institutions, is detrimental in the long run as many waste their time and money in futile direction.
Factoring the globalisation that drives significant market changes and immigration, it is clear that the individual is a foot soldier who 's faith unknown.
Recently I notice in Australia at least, hundreds of job in engineering and related, advertised by 99% recruiting agencies. I thought wow the market must be hot ,,,, but I doubt I think is rather flat......so I wonder now what the many recruiting agencies are in fact doing ?
That would be true, in general, of any school you care to pick; unlike Lake Webegone, there is no school where every graduate is above average. Every school has slackers, party hardies, etc. That's not particularly meaningful nor useful. A B+ GPA graduate from UC Berkeley, Caltech, or MIT is still statistically more likely to be a better engineer than a B+ GPA graduate from most schools.
I'd recommend a statistics refresher. Even adding the Ivys to those schools, you're still talking about a statistically insignificant number of graduates, <1%. You'd also be discounting a major chunk of the total population, not bc they didnt attend one of these schools but bc they werent eligible through no fault of their own. Collegiate grade inflation aside, many of these "top" schools only consider candidates from high schools which unethically inflate student grades beyond a 4.0 on an almost infinite scale, much the same as many colleges do today.
Speaking of statistics, where would I find such as school, since the highest weighted GPA I've seen is 5.0, and I think it would be pretty obvious that something was amiss if a student graduated from high school with even a 6.0, don't you think? And, what is "almost infinite," is it like 3/4 of infinity or higher?
I suggest that you do some research on what you claim grade inflation, when most schools have a rigid formula for what classes get higher GPAs, which are those that represent AP or honors, or IB that impose a greater burden on the student to achieve an A grade, compared to a normal class.
Some of that would depend (I think) on what I was doing. The Stanford guy would probably be good if I was at a R&D firm.....the A&M guy if I was doing more (straight up) design work.
Or would he? I worked with a A&M guy once (who was right out of school)......and he turned a (5 minute) single footing design into a 2 week research project. You never really know what you are getting.
I've been to more than a dozen state and national school boards' association conventions as my family has long been heavily involved in education, no need to research anything thanks.
Yes, some schools may adjust student grades back to 4.0 when using an extended scale and/or offering extra credit, unfortunately many do not. There is no national standard for K-12 scoring and even state standards are rather rare, the logic being that schools are free to grade as appropriate so long as students are passing standardized testing. In many districts this leads to students having GPAs above 4.0 on a 4.0 scale, with the only real limitation to their score being the amount of inflation the schools offer. The grading scale is indeed "almost infinite." Regarding AP courses and "normal" classes, I wouldnt differentiate the two. ~1/3 of students take and pass AP courses but most students are eligible, and many "top" students' local honors courses today are courses taken through a local university rather than the quasi-college AP offered to the masses.
Circling back to the topic of "top" colleges, as mentioned many of these are proudly open only to those students with unethical, unrealistic scores that don't accurately compare them to their peers.
A lot of schools boast about "passing" the AP exam, which gets you a 3, and not much else, and even then their statistics show that 40% of their students get less than a 3.
In my local high school, having fewer than 90% of the students getting 5's would be a lousy year. The high school AP Calculus class is tailored to match the state college calculus class, and the student get state college transcript credit for that class.
How many students can you buy for 40 bucks?
Is book smart the same as actual ability?
The book-smart grads - most of whom who are far better qualified than I am, on paper - struggle because they have nowhere to learn the practical skills needed, and an operational plant doesn't make for a great sandbox for them learn safely. They have little feel for how things work in the real world, and although they are smart enough to recognise this shortfall they just don't have any way of fixing the problem.
I'm just waiting to hear the next person ask me if we can measure GIC (1/2 Hz waveform) with our current fleet of relays. Why is the answer not right there for those with electrical backgrounds?
All that for a maybe once in 100 year event.
spraytechnology - I remember Thatcher's reign all too well.
The point is that not all engineering schools teach practical engineering. And for those who are better suited for lab work, great do that.
The same with text books. The real world requires some understanding, not just theory.
I think what happens more often is that industry doesn't know what to do with someone that constantly wants to see knew stuff and gets tired of repetitive routines. Most of the Ph.Ds I have met in industry were very capable and the worst were being used in ways that didn't play to their strengths. The employer hired the Ph.D so they wouldn't have train them on certain software packages ,for example, but once past the initial training in there wasn't any room to progress.
I think this depends on the company you work for. I find that most of those missing middle-aged 'engineers' have tended to go down a project management route in the company I work for.
Also, given that most engineers never did work for nationalised industries, your diagnosis for this apparent shortage is highly unlikely to be true. Indeed you'd have to assume that a good chunk just left the industry completely upon privatisation, and we all know that is not what happened: the vast majority were re-employed, often in the newly-privatised companies they were given redundancy payments from; 'same old British Rail', and all that.
Nonetheless, the notion of a shortage of engineers seems to run against the evidently disappointing wages: if there was a shortage, then surely we'd be more in demand and have higher salaries? Or perhaps it's just because we're a male-dominated, fiercely competitive industry in a race to the bottom all of the time? I'm not sure what is depressing wages, but it is depressing and doesn't live up to the promises made pre-university. Sure, the work is interesting, but the wages should be better (at least here in the UK).
If there is a skills shortage then it is likely to be a good thing for those of us left in the industry. However, I don't believe there will be a skills shortage given the drive for automation in engineering - a large number of jobs will not be required in future.
You're exactly right that a lot of the guys who left with big redundancy payments in the late 80's and early 90's set themselves up as consultants and were immediately re-employed by their former colleagues who were still on staff. Those one-man-band consultants have no staff of their own to pass on their expertise to, and indeed they have good commercial reason not to do so. The last of those guys are hitting retirement though, and as they do a massive gap in knowledge is opening up between those who are retiring and those who would be replacing them if the industry had some kind of succession planning. The power industry in the UK is dumbing down, and the industry knowledge is becoming concentrated in a few big OEM's based overseas.
I see the problem as the business people see no shortage, where as we see few qualified people. So I am guessing that the large number of unqualified people appear as there is no shortage, while we have open positions for several years because we can't find qualified people.
Sort of a disconnect in the business side and reality. In the end what do you think will happen? Say maybe large outages due to unqualified people doing the power engineering.
But it is correct that 'hard to fill' positions are not paying as well, and that maybe because most of us are not that willing to change employers.
There are a lot of things working against power engineering wages. You basically have to move to work for another utility. It is often less of a headache for utilities to just outsource the work. It is difficult to get on a utility's bid list so a large amount of outsourced work is sourced through a very small number of consulting companies. Utilities are regulated. Some consulting companies are only maybe 20% citizen labor. There is a prevailing belief that still carries that power engineering didn't pay well so it shouldn't have to pay well, even in a shortage.
UMD 1984
UCF 1993
How often does a desperately stretched engineering team feel forced to settle for the least-bad candidate on the basis that any help is better than no help? I've done it - not through choice, but when faced with a shrinking pool of talent to recruit from and a ever-growing backlog of work sometimes you reluctantly accept that an imperfectly filled position is better than an empty seat.
Some that apply simply don't even have a engineering background.
Now mind you I am in the US, and I believe ScottyUK is not. But it is interesting that both of us are in the same industry, and have the same problems, although in different conntries.
The other issue we have is that, at least here, is that it is difficult to bring in someone from another country because of the background check requirements for many of the engineering positions.
And that maybe one of the reasons why their is a shortage in the power industry.
When the best-presented candidate to pick from is still only 30% of what you're looking for, do you still take them and train them? I'm an engineer, not an alchemist, even though sometimes it feels like I'm expected to turn lead into gold.
cranky,
I agree, there's a global shortage of good, experienced power engineers. In the UK the chance to start training the kids with real potential was missed twenty, thirty years ago. They've entered other industries and made good careers for themselves, but in that time they've gained few of the technical skills we need, and it is impossible to set the clock back to repair the damage done to the industry years ago. The true extent of the damage has only started to show in more recent times, too little and too late.
Since the markets are saturated with candidates good and not so good, frankly if you have a need and you really want to recruit someone you will. I know and have seen it before jobs get advertised and go on unfilled, mainly with the large entities, for years. Nevertheless nowadays have companies advertising for openings is another PR brands promotion exercise.
I also have a coworker who is teaching two power classes at the local university, who keeps an eye out for potential hires.
On the other hand, we are small as far as utilities go, but we also have other groups that do things other than electric, so we have a number of civil, chemical, mechanical, and industrial engineers that can fill in some of what was once looked at as electric roles (planning, resources, project management etc.)
We also use retired people for short term fill in's, and consultants.
What do you mean passing on the best presentec candidate?
My question is who succeeds more, the guy who reads the description and moves on when he sees a "must have" he doesn't have or one of the many who apply anyway? Is there an unwritten rule somewhere that says that hiring managers EXPECT no one will meet all their requirements? If that's the case then I've been playing the game wrong and missed out on many opportunities because I'm honest and believe the hiring managers are really stating their needs!
(aka Electronic Packaging)
UMD 1984
UCF 1993
Like you, I'm trying to be honest, and not waste anyone's time, and will not bother to apply if I don't have a 'must have'.
Mike Halloran
Pembroke Pines, FL, USA
Recruiter gets his cut one way or the other the moment he finds a candidate well packaged for the client and the hiring manager is on company time.....
Cheers
Greg Locock
If you want a specific job, you should meet most of the requirements.
If you want a job, you should meet at least one requirement the company needs.
The problem is often the manager knows what he wants, but has no information of the people market. (Knowing they won't find everything they want).
The personal department knows how to hire in the craft area, but not in the engineering area. (Believing there are 100's of people who qualify for the job).
So the two seem to find a way through the weeds.(With only a few who might qualify, but will not be everything they want).
It's always a tight engineering market.
Few people look for a great job, most look for a great place to live. So why do managers tell you how great a place it is to work, and so little about the community?
"The traditional concept of the profession (the concept that is undergoing change) provides an interesting contrast to the concept of the profit-maximizing business firm. In the business model, the goal is profit maximization in a competitive environment that operates in a basically Darwinian fashion (survival of the fittest); risk is pervasive and both extraordinary profits and devastating losses are real possibilities. Employment and leadership in such an environment attract many and repel many. The people it attracts tend to be aggressive and daring. The ones it repel tend to be cautious and thoughtful.
In the traditional professional model, risk both upside and downside is trimmed by a combination of regulation and ethics both aimed at muting competition. With muted competition the lawyer or doctor can realistically aspire to a safe upper-middle-class income, but he is unlikely to become wealthy. The result, in combination with requiring postgraduate education and qualifying exams for entry into the profession and subjecting members of it to professional discipline, is to attract a type of person quite different from the entrepreneurial type—the latter a type exemplified by such extraordinarily successful college drop-outs as Bill Gates, Steve Jobs, and Mark Zuckerberg. The professional model attracts a more studious, intellectual, risk-averse type of person.
Why does society value such persons and create a comfortable niche for them? The answer is that some goods and services involve a degree of complexity that makes it very difficult for consumers to evaluate the quality of the goods and services. Legal services and medical treatment are important examples. Both involve considerable uncertainty (even the best lawyer loses some cases, even the best doctor fails to cure some patients). When a consumer is unable to determine the quality of a product or service, the provider has to be regulated, either directly as in the case of the regulation of the drug industry by the Food and Drug Administration or indirectly as in the professional model, in which the conditions for becoming a member of a profession encourage self-selection by persons likely to be trustworthy, responsible, and ethical because less inclined to cut corners in order to make a killing.
The professional model in law began to wane in the 1970s, with the beginning of the deregulation movement, which loosened restrictions on competition in legal services. The trend continued in subsequent decades, and was marked by an increased spread in earnings within law firms, an increased dispersion in the size of law firms, and increased turnover—in particular, the tendency of successful lawyers to move from firm to firm (taking their clients with them) in quest of higher incomes. Today, law firms closely resemble business firms. I am speaking mainly of law firms that handle corporate business, not of criminal or tort lawyers, who tend to practice by themselves or in small firms."
I fully agree with the idea that engineering consulting has and will continue to evolve from the professional to the business model. The interesting point that Posner raises is, "The professional model attracts a more studious, intellectual, risk-adverse type of person." It will be interesting to see how this type of person changes in the new business model - - with a central focus on profit-maximizing activities in unregulated (or under-regulated) competitive markets. Greater movement toward the business model produces an environment of increased risk. Consulting engineers may not want just a comfortable upper-middle-class income in the future; they may want to be rich; and one reason is the increased risk they face.
RE: A coming engineering shortage ? ---- Who agrees ?
I don't believe I've ever had so much as a phone screen for a position that I didnt meet every requirement and at least several of the preferred qualifications. I've also had recruiters tell me many times both as a job candidate and as a hiring manager that neither they nor their system are allowed to pass along candidates who do not meet every requirement, often this results in positions going unfilled for years.
Hiring managers are likely to get what they are looking for, and yes they need to invest their own time and candidates get closer to their dream job.
One of my adventures was with a manufacturing company. We had a modest number of CNC machine tools, and advertised for experienced help.
A really nice guy showed up, with no applicable experience, but a really strong Positive Mental Attitude, a photographic portfolio, a sweet smile, and a sad story about how badly he needed the job. ISTR he was a musician, and maybe a luthier too, but he didn't have enough experience with power tools of any sort to be scared of them.
The shop boss tried him in four jobs; in each, he listened to a briefing, indicated understanding, started off strong, then screwed up and damaged the machine or himself. He lasted most of a month. We were sad to say goodbye, but we feared the next personal injury would be a really bad one. He had not grown up with high forces and stored energy anywhere in his environment, and was not learning to appreciate the risks in ours, despite instruction.
Mike Halloran
