Transform the data on te x-y graph from pdf to excel
Dear Master
Could you please tell me how to transform the following attached pdf x-y graph data to the excel ?
Since I saw someone do this trick and made a Multiple regression equation so that we can plug a variable to
get the answer we want.
Thank you very much for your suggestion and guidance.
RE: Transform the data on te x-y graph from pdf to excel
TTFN (ta ta for now)
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
Seems to do what Tracer does, more or less, but seems to have a couple of nicer features. I haven't actually tried to use it yet, though
Its free and open source, and please ask if you have any problems using it.
https://newtonexcelbach.wordpress.com/2012/09/26/d...
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
I've used "GetData Graph Digitizer" for many years and it performed well. I downloaded your spread sheet and tried it. It works like a charm and I intend to use it from now on. Thanks!
It is still hard to fit the following non linear data to get the equation from gnuplot. Could you please share any thought ? Thank you very much.
