Thread Length, Engagement Various Materials
I am intersted in information regarding the recommended thread engagement for different sized bolts (coarse thread, grade 8) in various materials...most notably ASTM A36. I'm bolting two pieces together, on an angle, so my threads will be 7/8" long using a 1/2" bolt, OR about 3/4" long using a 5/8 dia bolt. I need to decide which to use.
Also, I have a table describing recommended thread engagement w/r/t the Ult. Tens. Strength of the bolt material (ksi) and the "SHEAR STRENGTH" of the parent material...I can't find any data on "shear strength" anywhere...I can find Shear Modulus...how do these relate. I need some help here Please!
RE: Thread Length, Engagement Various Materials
In steel, recommended thread engagement length is 1.5D where D is bolt nominal dia. Holes tapped into soft aluminum or magnesium based alloys would be better with 2D.
As for your question on shear strength, this may be measured either by single shear (in a simple two-plate sharp edged guillotine. Double shear testing is preferable in which a sharp-edged blade of finite thickness slides in a stirrup which carries a semi-circular recess to hold a cylindrical test-piece.In this case shear strength is max compressive load divided by twice (two shearing planes) the test-piece cross section. This test is common for aerospace bolts and test is described in MIL-STD-1312-13
yates
But isn't "shear strength" simply a mechanical property of the material? The chart I have askes for a quantity w/ the units of ksi.
I recall seeing this once as a similar fact for bolts as well...ie. the shear strength of a bolt is 6/10ths of its tensile. Does this sound right?
Thanks!
Thread725-35222
Ultimate shear strength = 0.6 x ultimate tensile strength sounds right.
As I said in my previous post, the ultimate shear strength can be approximated using 0.6 * UTS. It doesn't matter if it is a bolt, a tube, a shaft, or an intricate aluminum alloy sand casting for an engine block. If you need to know exact values for ultimate shear strength, then you will need to have the tests performed, such as NASM1312-13 (the replacement for the cancelled MIL spec MIL-STD-1312-123).
You can download the RCSC specifications for joints using these fasteners FREE at http://www.boltcouncil.org/
These specifications address you question about thread engagement.
I'll have a look.
