Required Bridge Survey Data for FEMA AE Study
Could anyone summarize what you believe are the FEMA survey requirements for bridges in an AE study? Based on the old 2003 FEMA Guidelines and Specs, it appears size/shape of opening, invert elevations, type of wingwalls/vertical abutments, deck thickness, high/low chord elevations, embankment sideslope, width of roadway, and roadway profile would be required. Subsequent guidance (2009 or 2016) is not as detailed, and I've been told the survey standards are now left up to the engineer/surveyor, but subject to FEMA approval.
If you have as-built plan sets (old NGVD29 datum), can these be used in place of new survey data if converted to NAVD88? I'm curious what everyone else has experienced in working through a new AE study.
Thanks!
Thanks!
RE: Required Bridge Survey Data for FEMA AE Study
