Wireframe isometric from isogen
Does anyone know how to generate a wireframe iso from C2 rather than the typical centerline isos that C2 generates through Isogen ?
Intergraph provides the wireframe isometrics in their training docs but they only explain how to get the normal piping isometric models.
RE: Wireframe isometric from isogen
If you use Isogen you will obtain single-line isometrics. The double-line and wire-frame views are generated by the CAESAR II graphics, not an external package.
Richard Ay
Intergraph CAS
Thank you for the information Richard.
Then the typical wireframe isos in your training docs are just an export of the graphics in wire-frame view and not any special options correct ?
Correct.
Richard Ay
Intergraph CAS
