Fittings for drainage.
Which kind of fittings are preferred for drainage pipes. I have two choices, one is fittings with mechanical seal and the other is fittings with solvent seal. i'm not sure which one to choose. can any one help me out.
RE: Fittings for drainage.
Standard plumbing drainage would be PVC or Cast Iron
If you are using PVC, then solvent fittings are the norm.
Typical cast iron fittings are not considered mechanical.
If you are wanting something special, like stainless steel or maybe even glass for acids or chemicals, then mechanical fittings would be appropriate.
