Resource for common soil index properties
Greetings all,
I have been scouring through resources trying to find a comprehensive list of common soil index properties for various different types of soils that I can have on hand and reference when I need to run some quick calculations. Ideally, I would like to see a list of all common soils with respective unit weights (dry, moist, saturated) with respect to density/consistency, as well as friction angle, cohesion, etc.
Have any of you come across something as complete as this?
Thanks!
RE: Resource for common soil index properties
Check out the "Handbook of Geotechnical Investigation and Design Tables" by Burt Look. You should be able to located a free PDF version online.
Any soil mechanics book will have typical information for soil properties, but if you want something quick, look at this link:
http://www.geotechdata.info/parameter/angle-of-fri...
USACE and NAVFAC manuals include also lots of useful information.
Check out the web site for this member. There also is a pile hammer web site with publications, but I can['t recall name.
www.SlideRuleEra.net
Also the NAVFAC info is available on line
