STEAM RELEASE TO THE FLARE SYSTEM
In order to avoid steam vapor plume, from a third stage vacuum system ejector outlet, to be seen in the atmosphere, it was advised to connect this steam to the flare system.
To me it seems a wrong idea but I have not strong reasons to convince it.
Did someone faced such a situation and what were the reasons to do it or avoid from doing it.
Thanks and regards,
roker
Thanks and regards,
roker
RE: STEAM RELEASE TO THE FLARE SYSTEM
On the other hand, another option would be to route this stream to the sour water stripper if your stage 3 ejector exit pressure is adequate? - that would address corrosion issues ( H2S / ammonia ) also.
Vacuum Distillation Units (VDU) in petroleum refineries have this stream routed to VDU furnace, to a separate burner, in majority of VDU designs I am familiar with. Depending discharge gas composition and the circumstances in your plant, you may be forced to use other solution. Sour water stripper, as mentioned above, or an incinerator, or off-gas compression/recovery system , might be the options.
Dejan IVANOVIC
Process Engineer, MSChE
