Pavement Moisture Barrier
To prevent underground moisture penetrating into top pavement, I heared that a layer of a moisture barrier can be applied just beneath the pavement. This technique might have been used at Tennis Courts. Do you know where I can find the technical information about the moisture barrier and the manufacturers?
RE: Pavement Moisture Barrier
Russ Faust
Salem, Orgeon USA
KRS Services
www.krs-services.com
