How to change the material orientation in ABAQUS???
I am trying to make a model consisting of a tube being deformed to a triangle cross section. I wanned to have a homogeneous orientation, meaning that I wanned that the first material orientation (x) to be in a same direction for all the elements (and the same thing for the second material orientation (y)). Even I changed the material orientation in the part section but in the end the odb is still with a messed up orientation. can somebody help me please?
here is the orientation that I choose in the beginning:
http://files.engineering.com/getfile.aspx?folder=d...
and here is the orientation in the end:
http://files.engineering.com/getfile.aspx?folder=6...
RE: How to change the material orientation in ABAQUS???
After a datacheck you can open the odb and look at the resulting orientations.
