View Arrangements in Teamcenver Visulization
I am running Teamcenter 8 and NX 7.5.
I have been told that by checking the '‘Synchronise Assembly Arrangements’ option within the 'Teamcenter Integration for NX' in Customer Deafults that this will allow for arrangements to be selected and loaded within Teamcenter.
I have the desired assembly loaded in Structure Manager, however when I go to 'Tools - Arrangements - View / Set Current' I get an error messaged saying 'No arrangements found - the root assembly has no associated arrangements'.
Anyone know how I can get this to work? Thanks.
RE: View Arrangements in Teamcenver Visulization
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
In case you have much data in TC that you want to have arrangement data available for you can run "refile" which is a batch operation that re-saves NX files.
Tomas
