Vacuum chamber flat end-caps
Hi there,
I have to design a vacuum chamber, big in diameter (~2.5m in diameter). On one end I have to use a flat cap, as thin as possible.
My first challenge is how to compute the stresses in this end-cap. I learnt how to calculate deposits with round endcaps (hoop stresses...). But how does one check this one it is flat?
thanks
regards,
thanks
regards,
RE: Vacuum chamber flat end-caps
These types of chambers are generally designed to a know world-wide Code.
At 2.5m you'll probably need some radial reinforcement. It's a complex model?, especially at the connection to the chamber. You might need FEA.
It will either need internal bracing or it needs to be domed.
Why does it need to be thin? Will there be room for gussets?
A thin wall requires accurate design analysis, high quality fabrication, and all sorts of inspection during fabrication, and after installation. You are adding cost to your design and fabrication. I hope you are adding value somehow.
JHG
What's the penalty (safety and cost) if it (well, when) does fail catastrophically if your stress model is wrong?
For now I am interested about the end-cap, the cylinder will come later. What code?
Bucking is important, but on the other hand we have "only" 1 bar of pressure difference. In principle we have just a cylinder with flanges and the endcap. I tried some FEA, but since the cap is so thin (I used 1mm) wrt the diameter it is not easy.
In principle bending is not a big problem, the problem is it should not break
It needs to be thin because particles go though it and we want to "see" them, if the material is thicker particles get "broken" in the material. ribs/bracing/stiffeners are also bad (more material)
No problems with vibrations or fatigue, it will be placed on a hall.
Here is a picture of something similar, but in this case they used the domed geometry.
http://cds.cern.ch/record/40739?ln=en
What I would like to know now is how to calculate a circle; clamped on the edge with 1 bar on one side. I can calculate beams (one dimension way bigger than the other two) but a flat surface...
Link they do blades for ID saws (look at page 10 http://www.winter-superabrasives.com/uploadedFiles... ) I have also seen systems where they clamp them flat then use hydraulic pressure is a groove to tension the blade.
If you are using a plastic film then perhaps stretching the outer edge over an o-ring would allow you to tension and seal it.
It is going to take some very sturdy flanges to carry the load without distortion.
Work out the load. It might only be 1 bar, but it's a big area and works out to be 50 tonnes force.
That's a lot for 1mm to try and hold back. ...
Is the transparency of your end a function of thickness, or is mass or some other material characteristic important too?
JHG
The main problem you have is that the vacuum tank puts the shell in compression, unlike a balloon skin.
"It needs to be thin because particles go though it and we want to "see" them," ... particles, what, like sub-atomic particles ? we are talking steel for the endcap material, right ?
I think your best approach is to dome the endcap somewhat. If you dome it outward, you may get a somewhat satisfying (if really disconcerting) span-through ! It should minimise the amount of stiffening.
It may be "only" 1 bar pressure to you, but to me it's an enormous load ... 2.5m dia = 98in (call it 100in), near enough 8000 sq.in, over 115,000 lbs, over 50 tons (or tonnes)
from Roark, max. moment = 3.3/16*14.7*50^2 = 7600in.lbs; 1in thick, stress = 46ksi
Then your 1 bar vaccum pressure - that "minor" 50 ton load is on the outside of the PV, the target and sensor are on the inside of the PV, and the thin membrane needs to maintain the pressure diffierence between the accelerator interior (a "pure" vacuum) and the sensor pressure vessel, a "dirty vacuum with an access port.)
Mike
I talked to a colleague today, there will be an inner hole with a flange in the middle, with a diameter of 1000mm (~3ft) and the outer would be 2400mm (~8ft).
3 materials will be considered: aluminium foil, kevlar and kapton foil.
Yes, subatomic particles will go through. The "transparency" depends on the radiation length (let's say not dense materials and with low atomic number)
I was thinking about 1mm thick. The picture of the kevlar dome is .85mm
rb1957, could you point out to the formula in Roark where you get those numbers?
I got the book today and found very long formulas for calculations, I'll put them in excel tomorrow
We need to make it flat so the particles trajectory through this cap is as short as possible. With the dome idea they won't go perpendicular to the surface (not shortest distance)
racookpe1978, I can't put the detector inside the vacuum chamber. There is a big solenoid around and other detectors (which should be in a helium atmosphere). Also maintenance would be harder in vacuum.
Thank you all!
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
would you not think that with all the resources available to CERN that they would have used a very thin flat plate if they could??
The dome shape is very strong - think of an egg shell - about your 1mm thick - It will withstand large forces when pressed from the pointy end, but direct that force at 90 degrees to the shell and lo and behold it cracks!
What you're trying to do is physically impossible. You will need to change something, be it the pressure, the thickness or the shape of your end connection.
you won't make a vacuum chamber, you'll make a little crushed bag of foil.
Check out the youtube videos of train tanker cars imploding because of drawing a vacuum on them. I assume they were being emptied with a pump and they weren't vented. It looks like a special effect out of a Hollywood blockbuster.
and Timoshenko dealt extensively with round plates (since they solve nicely !).
seriously, your options are ...
1) a flat bulkhead, but thick,
2) a flat thin bulkhead, but with stiffeners,
3) a domed bulkhead, can be thin (but I doubt foil will do it)
It needs to be thin because particles go though it and we want to "see" them, if the material is thicker particles get "broken" in the material. ribs/bracing/stiffeners are also bad (more material)"
Absurdly mutually exclusive. Apparently you have not even run the calculation. Your 2.5-m diameter will have 56 tons of force on it. Anything thin will be ripped to shreds. There's a reason why flat vacuum chamber walls look like below. You need a few inches of steel to have it not buckle. Your basic premise as described makes no sense whatsoever. If it's permeable to ANYTHING, it'll be permeable to air, so even if you could pump down one side, the permeability will allow room air to rush into the other side and overwhelm the high vacuum pump. And why would you ever want a 2.5-m membrane? An inch or so would be more than enough to demonstrate permeation, and would allow you to have a mating chamber with only the species of interest. Even if the source is large, there's absolutely no reason why the interface has to be large.
TTFN (ta ta for now)
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
