415v motor heaters
415v motor heaters
I have noticed some 415V motors have heaters fitted, but others dont, is this just down to the design of each particular motor?
All HV motors have heaters fitted.
Hallmg.
Hallmg.
RE: 415v motor heaters
In addition there are other ways of heating LV motors via low voltage transformers, solid state "motor winding heaters" and some VFDs. Those options are not available for MV motors for the most part.
"You measure the size of the accomplishment by the obstacles you had to overcome to reach your goals" -- Booker T. Washington
Thanks for the info.
Hallmg.
