NX Dimensions not Parametising Correctly
Dear eng-tips,
I have been trying to create parameters from sketches. (Drawing lines and adding a rapid dimension to define lengths.
Regardless of whether I use the default pXXX or rename the parameter (e.g L1), NX is not generating the formulae correctly.
If I open Tools>Expressions and set the listed expressions filter to 'All' my values appear in the list. However, if I view these parameters in Spreadsheet Edit it is clear to see that no formula is linked! (THE CELLS IN COLOUMN B ARE NOT GREEN & CANNOT BE SELECTED FOR USE IN OTHER PARAMETERS)
Could someone please tell me if I there is a parameter setting somewhere that I have turned off?
Kind Regards,
Chris Swain
Kind Regards,
Chris Swain
RE: NX Dimensions not Parametising Correctly
Tim Flater
NX Designer
NX 9.0.3.4 Win7 Enterprise x64 SP1
Intel Core i7 2.5GHz 16GB RAM
4GB NVIDIA Quadro K3100M
Its NX 9.0.3.4 MP11
The same version that you are using Tim!
Can you post an example of a formula that you are trying to create? What were the exact steps you used in your attempt to create the formula?
Did the same workflow give different results in a previous version of NX?
www.nxjournaling.com
Turns out that the problem was in the fact that I had converted from mm to inches in the original parameter.
If there is a formula within the original parameter then the parameter does not generate correctly.
(E.g. 0.5/25.4) equals 0.5mm in inches.
I fixed the problem by changing the sketch units to mm instead.
This can be done in Analysis> Units Custom> Unit Manager
Chris Swain
