SA 516 Gr.70 - "killed" on certificate
Referring to this thread
thread330-209627: SA516GR70 - Fully Killed ?
I have a certificate of SA 516 gr.70 plate. It's written that it is according to SA 516, but It's not written that material is killed (as required by par 4.1 ASME II PART. A, SA 516). Is this material acceptable for ASME? thanks
RE: SA 516 Gr.70 - "killed" on certificate
Yes, it is acceptable for ASME B&PV application.
Just to clarify your 3.1 cert is the same as an MTR - different countries, different terminology.
You actually have a Material Test Report (issued in accordance with ISO 10204 Type 3.1) but you probably call it a Material Certificate or Mill Certificate,
Cheers,
Shane
You might try to refer ISO 10474 or EN 10204 type 3.1 in your post.
4.1 steelmaking practice
The steel shall be killed and shall conform to [...]
thus every grade from ASTM A516 is killed
