How to get distance between two points using C++ CAA?
I have created a point and projected it on a body by writing code in CAA. Now my next task is to get distance between those points. How can I get it?
I have used GSM Factory- CreatePoint point method for creating point and CreateProject for projecting it on body.
Please find the code I have written:
//creating point
double dPointCoord[3] = {pointList[i].GetX(), pointList[i].GetY(), pointList[i].GetZ()};
double* pPointCoord = new double[3];
pPointCoord = dPointCoord;
oPoint = spGsmFact->CreatePoint(pPointCoord);
spDescendants->Append(oPoint);
spiSpecOnGSMTool->Update();
//projecting the point
CATISpecObject_var iToProject = oPoint;
CATISpecObject_var iSupport = spCurrentTool;
CATIGSMDirection_var iDirection = NULL_var;
CATBoolean BoolNormal = TRUE;
CATGSMProjectSolutionType SolutionType = CATGSMNearestSolution;
oProjectPoint = spGsmFact->CreateProject(iToProject, iSupport, iDirection, BoolNormal, SolutionType);
spDescendants->Append(oProjectPoint);
Thanks in Advance!
Yashodeep Patil
//creating point
Thanks in Advance!
Yashodeep Patil
RE: How to get distance between two points using C++ CAA?
Measure it using SPA Workbench. Here is an extras from CAA V5 help to point you to the right area:
Func GetMeasurable( Reference iMeasuredItem) As Measurable
Returns the Measurable object.
Example:
This example get the Measurable from the SPAWorkBench.
Dim referenceObject As referenceObject
Set referenceObject = "GetReference"
Dim TheSPAWorkbench As Workbench
Set TheSPAWorkbench = CATIA.ActiveDocument.GetWorkbench ( "SPAWorkbench" )
Dim TheMeasurable As Measurable
Set TheMeasurable = TheSPAWorkbench.GetMeasurable(referenceObject)
cilici
