Help with making a flexible assembly
Hello! I'm new to this forum, and to solidworks.
I want to make a gear subassembly with two axles and meshing gears. However, the first part inserted in the assembly (an axle) becomes rigid, and so when the final mate (a mechanical gear mate between the two gears) is made, of course the whole assembly is rigid. Is there any way I can allow the first axle added to rotate so that the gear assembly will rotate as it would in real life? Or will this assembly function properly once this subassembly is inserted into the larger assembly? I understand that subassemblies can be solved as flexible, but this is simply an assembly of a series of parts, and those options are greyed out.
Thanks very much in advance, if any clarifications are necessary, please ask.
RE: Help with making a flexible assembly
