round vs flat shielding wire
I am looking at using wire spec M27500-20LE1S05 in place of M27500-20LE1G05. The major difference is the wire braided for the shielding would be round silver coated copper instead of flat. I am trying to determine how much of a factor the shape of the shielding wire is. As a mere mechanical, this question is completely beyond me. Any
information you could provide would be greatly appreciated.
Thank you.
Thinksalot
Thank you.
Thinksalot
RE: round vs flat shielding wire
RA
assuming that you are describing the cross-section of the individual wires rather than the over all shape of the braid, use of flat wire has to do with coverage effectiveness. for a given amount of copper you get higher coverage ratios for flat wire.
