Guide cables on roof air raising
See also thread1452-384612: Roof air rising
As far I know there are at least two ways to assemble the guide ropes. The most comun is to pass the ropes throught the roof and use the pulleys bellow the roof shells in the periferic zone. Another way is to have the same pulleys on the top of the roof and use just one hole at the roof's center. What is the best solution?
RE: Guide cables on roof air raising
Dear Marine1,
There is another option i.e. the pulley above the roof plate near the shell plate. I did use this method.
But mostly the pulley under the roof.
Syah
Syahar, could you explain?
