3D print worm gear to match COTS worm
Hi, I'm hoping someone can point me in the right direction. I have a lab/prototype system I'm developing that uses a worm gear to index a test sample. These are very light loads and low speeds, but is highly space constrained. I want to use a COTS worm gear to drive a 3D printed worm wheel of my own design. The worm wheel needs some fixturing features along with a larger pitch diameter than seems to be available from stock gear suppliers.
I can't figure out how to determine the correct tooth profile for my worm gear. I have some information about the worm from the supplier (for example, an A 1C 5-N24 worm from SDP) like the pressure angle, lead angle, lead. The SDP models seem pretty good, but I don't know if the tooth profile is accurate and if it was, is that enough info to create the mating worm gear tooth profile?
Anyway, if anyone could help point me in the right direction or give me some tips/references that'd be great!
Thanks.
-John
Thanks.
-John
RE: 3D print worm gear to match COTS worm
You can see that the worm wheel isn't generated by itself but by iterative cuts from the worm gear shaped hob.
An approximation would be a spur gear with helical teeth to match the advance angle of the worm gear.
If I didn't use camnetics, the spur gear w/ helical teeth would have been a good alternative. Maybe I'll try both and report back.
GearTrax for Solidworks
KISSsoft
Sizing calculations are available for all common gear types (cylindrical gears, bevel gears, worm gears, helical gears, hypoid gears, and crown gears). For cylindrical gears, the software also works with planetary sets and gear racks. In addition to a feature for reviewing calculations with respect to standards (ISO, DIN, AGMA, VDI, Klingelnberg), the program also offers a number of different design and optimization functions.
Also includes full transmission design/analysis
Gearotic http://www.gearotic.com (external link)
Spur, Helical. Bevel, and Crown; Involute, Cycloidal, Random, Geometry, CNC
Romax Designer
Gear noise prediction/simulation see Eliminating Gear Whine
ZAKGEAR *
Spline, Spur, Helical, Spiral Bevel, Gleason; Involute, Spirol?; Geometry, Inspection, Stress, CNC
Worm gear profiles should be described in your machine design textbook. I have modeled a worm and gear, although I did not do rapid prototyping. On the other hand, rapid prototyping is not a precise process, so you do not need to get the profile exactly right. The plastic will smooth itself to shape when you run it.
Is there any reason you cannot go to a gear fabricator with an engineering drawing? The part can be made from metal. You specify the tooth clearance you want, and you give them the worm so they can test it.
JHG
