Shaft Mat'l - ANSI 4140 vs 4150 ?
I'll post this in a couple forums.
We're looking at pump shafts, under 6" bar size. Other than the 10 points difference in Carbon content (per ASTM A29), I can't find an appreciable difference between 4140 and 4150 until you get around 8" bar size where tensile differs a little.
Assuming non-resulfurized, is there any reason - such as machining - that makes one better?
Thanks!
Thanks!
Keep the wheels on the ground
Bob
showshine@aol.com
RE: Shaft Mat'l - ANSI 4140 vs 4150 ?
I use a lot of 4145 which develops good properties up to 10-inch diameter and, when oil quenched, few problems of quench cracking.
Response from carburize is right on. Be very careful if the part is heat treated after machining and has any groves , small radii or rapid section change. A 6 in shaft is quite large, if highest performance is needed, consider 4340 which is deep hardening.
Gearman is right, but the cost increase for 4340 creates a problem.
Thanks guys!
Bob
showshine@aol.com
