Rehabilitation Code
Rehabilitation Code
Rehabilitation Code
Hi Experts ,
International Mechanical Code (IMC) does not allow corridor to be used for return air path.
Can we use corridor as return air path under 2012 Rehabilitation Code ?
RE: Rehabilitation Code
Would you want to draw smoke through an exit corridor?
What is the difference between two office's common corridor and two offices common return air plenum above suspending ceiling when the HVAC system is running
