Safe Loading for Wood Truss
I have 2x4 wood trusses 2'-0" O.C. spaning my garage that support the garage roof. The span is approx. 21 feet. The ceiling of the garage is finsihed with 1/2 drywall. The truss manufacture said that the bottom cord was designed for 10psf DL and 0psf LL. The top cord is designed for 10 psf DL and 35psf LL. I would like to use this area for some storage. What I would like to know is what loading (psf) can I safely put in this space, and if I needed to add some additional support....what would be the best way to do it. I was thinking of getting some 2x8's @ 12' long and spaning the garage walls between the trusses and lap-splicing them together.
DMX
DMX
RE: Safe Loading for Wood Truss
If you install a larger dimension bottom chord reinforcement with an adequate splice, you could consider the bottom chord as acting as a beam or joist, and the connection issue becomes moot.
