Tabular Note Issue
Tabular Note Issue
Greetings: I have a title block on my drawing sheet with a tabular note. There are data in the cells of the tabular note, but they do not display. If I double click on a cell, a window pops up showing me what is in the cell, but it does not display. Can anyone help me with this issue?
RE: Tabular Note Issue
If it displays ### NX considers the cell to small to fit the text. make the cell wider and the text should appear as expected.
Tomas
select the cell such that it is highlighted, ( not double click, single.) Then press Ctrl+I ( = Information - Object)
search the window for "font". Do you have that font in NX ?
Select the table and change the font for all cells.
Tomas
BW
