Mechanical Seal for Nitric Acid
Hello Dear members
I want your guidance in selecting mechanical seal. Which mechanical seal is best for handling Nitric Acid? Viton or EPR. if there is any reference
available.
Thank you
available.
Thank you
RE: Mechanical Seal for Nitric Acid
In this case it depends on the concentration of Nitric acid. If its between 0-50%, then you can use viton. Otherwise your looking at perfluoroelastomers I'm afraid.
