Reuse OOTB button icons on custom made NX 10 tools
I have started to make some custom automation tools and rather then come up with my own button icons/images, I would like access and reuse the existing icons that are relevant. Just specifying them in my men/tbr file. Is there a way to do this? What format are they in and where are they located? I have searched bmp, jpg, gif, ico, etc. and can't seem to find them.
Thanks.
Thanks.
RE: Reuse OOTB button icons on custom made NX 10 tools
If you go into customize you can copy the icon from a button..I suspect they are embedded in the executables...
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
what is that purple color code that nx recognizes as transparent ?
I tried rgb(128,0,128) but without success...
i googled :
nx icons site:www.eng-tips.com
and found this :
http://www.eng-tips.com/viewthread.cfm?qid=374010
I do not know if the zipfiles still are available on the FTP or not.
Tomas
If creating your own icons you will need to save them as 24 bit bitmaps to get the magenta transparency to work. See https://docs.plm.automation.siemens.com/tdoc/nx/10.0.3/nx_help/#uid:index_customizing_nx_installation:customize_interface:ui_customize_uic_cust_tl_btmp
Mike Hyde
www.astonmartin.com
NX10.0.3 with TC11.2.1 and Vis 11.2
RGB 255,0,255 for the background - and as already stated, save it as a 24-bit bitmap file (.bmp).
Tim Flater
NX Designer
NX 9.0.3.4 Win7 Enterprise x64 SP1
Intel Core i7 2.5GHz 16GB RAM
4GB NVIDIA Quadro K3100M
To use the built in icons, you only need to know the name, and the system will select the correct size for the location, such as on the ribbon.
Mark Rief
NX CAM Customer Success
Siemens PLM Software
Go to customize mode then right click on a button; choose change button icon -> icon name... The dialog that pops up will give the name of the current icon image.
www.nxjournaling.com
