Print a TIFF image
Print a TIFF image
Print a TIFF image
Hi everyone,
How can I print a TIFF file using VB6.0?
Any help will be apreciated.
MHendler
RE: Print a TIFF image
Not sure if this helps (or works), but Windows comes with Imaging.
Maybe you could load the TIFF file into Imaging and then print it from there.
Visual basic 6 doesn't support “*.tif” files.
Visual basic 6 loads pictures in image or picture box controls.
And loads only pictures with the: “*.bmp”, “*.cur”, “*.dib”,“*.emf”, “*.gif”,“*.ico”, “*.jpg” or  “*.wmf” extensions.
You have to change extension from “*.tif” to for example “*.bmp” (how to do that: open “*.tif” file with “Paint” and Save As like “*.bmp” file) and then put into your VB project:
For example:
1. ImgMyPicture.Picture = LoadPicture(App.Path & "\OnePicture.bmp")
‘one way
2. Or in design mode, load the picture, in image or picture box
controls, in their properties.  - other way
For printing image files VB6 uses Printer object and
PaintPicture method for example:
Sub PrintPictires()
Dim c As Control
For Each c In Controls
   If TypeOf c Is Image Then
        Printer.CurrentX = c.Left
        Printer.CurrentY = c.Top
        Printer.PaintPicture c.Picture, c.Left, c.Top
    End If
  If TypeOf c Is PictureBox Then
        c.AutoSize = True
        c.Refresh
        c.AutoSize = False
    End If
Next c
Printer.EndDoc
End Sub
Maybe this will help you.
