Extracting Modal Amplitudes of nodes from Etabs 2015
Hi All,
Can anyone out there tell me how to extract modal amplitudes for a set of nodes from Etabs 2015. I am completing a modal analysis for a slab, I can obviously see the modal amplitudes (for each node) on screen as well as all other displacements for my given load cases. However, if I go to Display>Show Tables I can only export tabular results for the displacements of normal load cases and not the modal load case.
Any thoughts?
JK7070
