concrete insert design
I have to design male and female concrete epoxy inserts with tension and shear load applied at top of anchors. Do I need to check the wall of outer insert for shear.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: concrete insert design
Professional Engineer (ME, NH, MA) Structural Engineer (IL)
American Concrete Industries
www.americanconcrete.com
I am trying to get more information about the insert requirement from field.
All I have is 8" 3000psi concrete slab with "4 @12" , 4" from top. the load on insert at top of slab is 8K tension and 8.5K shear. This will be post installed insert and trying to use per Hilti insert.
We're going to need a more accurate description of the application in order to help you further. As it currently stands, I'm still not totally sure what we're talking about.
I am trying get full picture of the problem. Thanks
Yes. I am using ACI 318 appendix D.
