Plate Stringer
Plate Stringer
I have a project where the client is using plate stringers to support precast treads on a stair. The precast plank is supported on a system of carrier angles that are welded to the bottom of the stringer. These carrier angles are then welded to an plated that is embedded in the tread. The question I have is in relation to bracing for lateral torsional buckling.
Since the planks are supported by these carrier angles at the bottom of the stringer I am inclined to say that the stringers should be checked against lateral torsional buckling for the full length of the stringer (unbraced). However, since the angles apply their load from the tread slightly eccentric to the stringer one could argue that lateral torsional buckling would take place "into the stair" and that the stringer would bear on the treads and effectively become braced. Problem is, I am not exactly comfortable with this scenario. What does the community thing?
RE: Plate Stringer
It would be good to see a sketch showing the proportions and nature of the connection.
