Material selection for produced water
Hi All
Based on the FEED report the properties of produced water is Chloride 1,43,000 ppm and H2S 1000ppm. But material selected is CS with 6mm CA and Valve trim is SS316. I want to know is it possible to use SS trim with out any coating for this chloride content and for the pipe also no internal coating is mentioned for CS material.
RE: Material selection for produced water
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
Its 143 thousand ppm.Please find the attached file for more details.
David Simpson, PE
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
Specialized in special industry valve
